![Embarrassed :oops:](./images/smilies/icon_redface.gif)
my fluid is slightly below the LOWER mark, i have spare dot 4, but how do i top it up. theres no info how to add it
![Image](http://img88.imageshack.us/img88/9981/cbsfluid125.jpg)
Alibally wrote:There's a small hole beside the ignition switch. You can see the level through there.
One day I'll shine a torch in that hole as in daylight all I ever see is a dark square, no level. Either I'm just not seeing the level line, or it's very full or too lowAlibally wrote:There's a small hole beside the ignition switch. You can see the level through there.
That works for the level in the reservoir on the handlebars, didn't know it also worked for the CBS reservoir. Don't believe the user manual mentions this 'trick'.yak wrote:My fluid was below the desired level so i took it to the dealer. The PCX mechanic said that the handlebars need to be turned all the way to the left before checking the fluid level. When i turned them to the left, the fluid was at the correct level.
