Drive belt
sedli
Drive belt
Post by sedli »
Hi, great forum with lots of information.
       Still can not find information on belt. What is the minimum width of the belt on the exchange? I have already driven 24,000 kilometers. The new belt is enough money, thinking about kevlar belt Malossi x. Dimensions are 22x10x816 correct? It must be replaced because my maximum speed decreases. Also the dimensions and weight of rollers I found, you know that? Thanks for the response.
Live to Ride - Ride to Live
Honda PCX 1.generation; 26000 Km
Re: Drive belt
The only belt worth spending any money on is the genuine Honda one.
The aftermarket ones are a false economy and that's being polite about it.
With one exception which is Dayco but I don't think they do one for the PCX.
skuuter
Re: Drive belt
Post by skuuter »
gn2 wrote:The only belt worth spending any money on is the genuine Honda one.
Nope, no Dayco yet.....Honda OEM is the way to go...!!!
sedli
Re: Drive belt
Post by sedli »
Original is the best way, i Know...but in the pcx is belt Bando form the factory, but dealer cant offer me Bando, only Dayco like original spare part....
So PCX is factory Bando, but you can not even get the official dealer. Only Dayco belt. That's why I asked about the Malossi, if not better than Dayco.
      Do I have to replace the belt and allow the rear nut on the clutch?
Re: Drive belt
Don't buy a Malossi belt, its a piece of garbage.
The clutch must be removed to get the belt out.
Re: Drive belt
What is the price of the OEM belt in the UK and the US?
sedli
Re: Drive belt
Post by sedli »
The price in the Czech republic is 60 GBP and about 90 USD....
I will buy original belt and rollers...I want change it home, so I will buy impact wrench...Do you know matrix size variator and clutch? Thx.
Re: Drive belt
No need for an impact wrench, you just need something hold the variantor and clutch with.
I got an original belt from eBay for just under £40 including delivery.
~Cheap_Ride~
Re: Drive belt
Post by ~Cheap_Ride~ »
A good solid strap wrench will work.
Carpathian hawk
Re: Drive belt
Post by Carpathian hawk »
Do not use Malossi drive belt; usually their life is half of an original belt by the experience of a lot of friend owners of scooters (many brands & models). If you use Malossi inspect more frecvently the belt.
An elecrical 12V impact wrench is a very good investment, but one with electronic adjustment of torque applied (80-90$), in order to administrate the exact momentum requested by Service Manual. Using other devices to fix the "variator" it is the risk to damage some blade of the aluminium cooling fan.
Currently own: 2013 Honda PCX150 red, 2008 Suzuki Burgman 400 red.
Carpathian hawk
Re: Drive belt
The tool I am talking; sorry for the language:
http://gema-online.shopmania.biz/cumpar ... act-884455
sedli
Re: Drive belt
Post by sedli »
Can I use the belt from the second to the first generation of PCX? They have the same dimensions? Otherwise, I bought rollers and guides. From the crash scooter. Even the belt. That is the second generation I realized after purchase. It's mileage 1500 km, so everything like new.
Re: Drive belt
Honda drive belt €34 : http://makinaparts.com/lang-en/honda/12 ... belt-.html
Bando drive belt €27 : http://makinaparts.com/lang-en/honda/34 ... -125-.html
(Honda belt is made by Bando)
Re: Drive belt
One of the advantages of living in Thailand is that parts are much less expensive. I bought an OEM belt from the dealer for 460฿ (£9.65 - $14.75 - €11.08). Maybe I should bring some back to the US with me later in the year. ;)
sedli
Re: Drive belt
Post by sedli »
So I lit a variator. Both parts of the variator are curled. Pin variator has the will. I think the brass pin. It can be seen in the photo. Thus fell the maximum speed. So far I composed it and ride away. I have to buy a new original belt and variator counterpart. But what variator? Malossi or Polini? It's about speed and not about starts.
variátor (14).jpg (53.48 KiB) Viewed 8661 times
variátor (10).jpg (63.27 KiB) Viewed 8661 times
Re: Drive belt
There's nothing wrong with the one in the picture.
Re: Drive belt
Ignore the black marks. Clean off with cellulose thinners? Then run a fingernail down the variator working surface. If it isn't hugely worn then its usable
sedli
Re: Drive belt
Post by sedli »
But how you can see on the first photo, the belt can´t go on the upper part of variator. It cause it that, the maximal speed is lesser than before...Before pcx take 110 km/h, now only 100 km/h.....Do you thing, it want only new belt and leash and everything will be how before ? Thnx.
Re: Drive belt
sedli wrote:But how you can see on the first photo, the belt can´t go on the upper part of variator. It cause it that, the maximal speed is lesser than before...Before pcx take 110 km/h, now only 100 km/h.....Do you thing, it want only new belt and leash and everything will be how before ? Thnx.
The belt will never ride to the very top of the variator. As it never has done looking at the markings
This is a bit of a safety margin to stop it jumping off
Re: Drive belt
Makes me laugh when people talk about the unused bit, they never think about whats happening at the other end and the belt length...
