pcx125 ..600mile maintance??
Pcx 125 just got too 600 miles ...what needs to be done too it???other than a
Motor oil change???
Motor oil change???
Re: pcx125 ..600mile maintance??
All I see is motor oil ....what u see in urs ??
Is kind of hard to understand it to be honest lol..
All you need to do is take it to the dealer, point at it and say "give that a six hundred mile service please".
- Alibally
That's what I would do as well to be honest, but get a price first. Some dealers seem to check the valve clearances at the first service and some don't. It makes a big difference to the cost as the labour time is quite high to do this.
It's an oil change and checks basically. Things can slacken off between leaving the factory and the first service. I think mine cost about £65 if I remember rightly.
The 600 mile service is basically the final part of the manufacture and assembly quality control process and should be entrusted to a competent individual.
Anyone who can't even make sense of the service schedule probably isn't up to the job.
Lol I change the oil .....and I know how to read the maintenance schedule now lol..
Im in delaware so the only place I can go is Honda east power sports they expensive there tho.
I really like my pcx so I wanna keep it up to part.... I been reading a lot of forums
And I see a lot of people talking about the Valve CLearance doesn't need to be adjusted .
a guy said his scooter has 10,000iles aNd he check his valves 4 times and they were fine..said only em
If u feel performance issues or a clicking sound....What ya guys think about that????..did ya notice a difference
After ya got ur valves service???????
Thanks for reading and answering my questions not
To many scooter people out here in Wilmington delaware LOL....
That is the general belief. Honda is overly conservative in the valve adjustment interval. Your mileage may vary.....hectyc302 wrote:Lol I change the oil .....and I see a lot of people talking about the Valve Clearance doesn't need to be adjusted (so often) .
A guy said his scooter has 10,000 miles and he checked his valves 4 times and they were fine.
The valve clearance check interval on my 1986 Elite 250 is recommended every 4,000 miles. I have 18,000 miles on it now and it still runs fine without any adjustment required.
Current - 2015 Honda CBR650F
Just checked my valve clearances, the scooter has done roughly 15,000 miles and the clearances were absolutely spot-on.
Given the amount of time the dealer took to do the services I doubt the clearances have ever been checked till today.
Kk thanks ya think overall I be k longest my scooter is ridin and sounds
Good??
Good??
gn2 wrote:Just checked my valve clearances, the scooter has done roughly 15,000 miles and the clearances were absolutely spot-on.
Hallelujah and pass the paracetamol!!
What u mean you you ??? So I guess I keep on riding to 2500 miles
And see what happens lol 600 right now so far good .... Question do ya let
Ur pcx heat up before riding or just turn on and go ??
At least do an oil change at 600 miles and clean the oil screen.
No need to let it warm up, just start and go but dont hammer it for the first few miles.
Kk...one more question ya When do I need to change my pcx gear oil????
Service schedule says every two years.
But it should be fine to leave it longer than that.
Great thanks
Just got a quote to service my pcx 300$$$ .and they will check my valve CLearance what ya think????
P.s I was at the light and my scooter cut off bit it turn back on fine ??? Some one said thats my valves is it ???
for what it costs, change the gear oil every year, 180ml oil, and fresh oil never hurt anything!!
Make sure to get the dealer to do the first service, you can do the rest from there.
It's important to do an initial valve check, mine were off on the 600 mile maintenance. After that, you can either keep with the schedule, leave it alone, or somewhere inbetween. It's a single-piston, 2-valve engine -- it likely won't drop or burn a valve, it'll just stop getting compression and run poorly. Adjust it then, then keep riding. It's a scooter, not a Ferrari.
