Afternoon all,
I’ve just completed my first home oil change, which for the mechanically-minded on here will be ‘so what?’ but for me was a big thing. My question is about servicing. I’d like to start doing as much as possible myself and would really like advice as to what I should aim to do next, and where to go for good ‘how to’ instructions. Thanks in advance for any advice you can offer.
DIY Servicing/Maintenance
Re: DIY Servicing/Maintenance
…and now I’ve just gone back to the forum front page and seen the ‘how to’ guides. Doh.
any advice I give should be looked at carefully . my body broke some more in old age, really rough 66 years.
Check the brake pads often. I always had a spare belt around.
The tires wear out quickly. I get tires from FortNine in Montreal for Canada
Parts are hard to get. Ebay??? Have a set of front and rear brake pads available
I sold my 2014 Honda Forza 300 with 180 thousand kilometers for $500 Canadian
My plastics were brittle. the fuel gauge is joke.
Die before you fall apart,
Now riding a Piaggio one active electric Vespa. 25 km per day. It will last forever at that rate. where are my tylenols?
What you've done ,is the main thing. Some go by the "book", The oil change is most important. Other stuff is probably good to do.
I've personally neglected much of it and got away with it. Of course expendables have to be taken care of, Like Dave mentioned.
If it isn't broke, don't fix it has worked for me. Your choice. Enjoy your new ride. Good to see you back Dave!
Check your final drive gear oil often gets overlooked when servicing also get a good quality spark plug they last aroung 10,000 miles and check your water header and lastly inspect your belt and rollers at least every 6 months
