https://www.youtube.com/watch?gD84iOOrM40&t=1025s
In this video I show you how to change front fork oil on Honda PCX 125 / 150 scooter.
More tutorial videos on PCX 125 / 150
PCX 125 - https://bit.ly/MicPCX125
PCX 150 - http://bit.ly/MitchPCX150
Are you subscribed? http://bit.ly/MitchsScooterStuffSub
- T O O L S -
Bucket
Oil seals
Wood blocks / floor jack
Rags - https://amzn.to/2Yh8jvg
Oil pan - https://amzn.to/3bOmT5Q
C-clamp 6” - http://amzn.to/2EU8xlm
Wire brush - https://amzn.to/3Jvi8gW
Rubber mallet - http://amzn.to/2BsqAMz
Fork oil WT10 - https://amzn.to/3Fw7hSE
Caliper digital 12" - https://amzn.to/3fULYeu
Scotch-brite pad - https://amzn.to/2xP621n
Marine grease - https://amzn.to/2UzmmLB
Ratchet 3/8 drive - http://amzn.to/2hhmnUs
Brake parts cleaner - https://amzn.to/2ZbZnbj
Theadlocker red gel - https://amzn.to/3LtSYly
Breaker bar 3/8 drive - https://amzn.to/3lrjIWj
Phillips #2 screwdriver - http://amzn.to/2fgdZDL
8mm socket 3/8 drive - http://amzn.to/2xLNVXU
10mm socket 3/8 drive - http://amzn.to/2xGuLSF
Tiny flathead screwdriver - http://amzn.to/2zyrLck
Threadlocker blue 242 - https://amzn.to/2SPbY1R
12mm socket 3/8 drive - http://amzn.to/2xM4Edr
14mm socket 3/8 drive - http://amzn.to/2xGn4Ms
19mm socket 3/8 drive - http://amzn.to/2CiXNqo
Syringe 100cc with tube - http://amzn.to/2G951U2
6mm allen socket 3/8 drive - http://amzn.to/2ELCnbU
32mm socket 1/2 drive socket - http://amzn.to/2wV9MNf
Torque wrench 0-150 lb/ft 3/8 drive - http://amzn.to/2Crqq4R
Fork oil level measurement gauge tool - https://amzn.to/3lolIBv
VIDEO - Front Fork Oil Change
- MicBergsma
- Color: white 150
Mitch's Scooter Stuff
YouTube - http://bit.ly/MitchScooterChannel
Instagram - http://bit.ly/2fB8gay
RandalllFlaggg
- Year: 2022
Re: VIDEO - Front Fork Oil Change
About two weeks away from my 2 year anniversary of purchasing my 2022 PCX, I found a puddle around my front wheel. Took a picture of it and showed it to the shop that I go to to get work done on it. I thought it was the brake caliper or lines. The guy said it was the oil from the forks. Kinda disconcerting because it happened when not even 2 years old, but he said cold weather can affect these seals. I'm in Colorado.
Taking it to the shop Tuesday to get it done. Thanks for the video.
Your videos remind me of the older Far Cry games set in tropical areas with the sounds. Keep expecting to hear Vaas start his, "Definition of Insanity," speech from behind you as you're twisting the torque wrench...
- Leak_5_6_25.jpg (95.14 KiB) Viewed 27013 times
