What disc lock will fit the Honda PCX 150? Standard 6mm? 10mm? Looking at one with alarm built in it. Suggestions?
Thanks!
Disc Lock Help
- khaosaming
Re: Disc Lock Help
http://www.hondapcx.org/viewtopic.php?f=7&t=489
Just a quick note before you buy a disc lock make sure its a 6mm one or it wont fit,
Ps anyone want a cheap 8mm disc lock
Re: Disc Lock Help
Xena makes the best I've used. The alarm is real sensitive, so much that it won't let you forget you've locked it. If you even move the bike, it warns you with a beep, then goes off.
http://www.xenasecurity.com/product/mot ... low/page1/
Before doing anything stupid, make sure there are no uninvited witnesses...
- khaosaming
Re: Disc Lock Help
At least in Thailand, Honda's Anti Theft Alarm system comes fitted with every PCX.
You see the small led just below the red speedo needle? It blinks when the alarm is activated.
![Image](http://upload.wikimedia.org/wikipedia/commons/thumb/c/cc/Honda_PCX150_2013_Speedometer.JPG/640px-Honda_PCX150_2013_Speedometer.JPG)
Re: Disc Lock Help
Sadly, we don't get the alarm elsewhere. I wish we did here in the US...
Re: Disc Lock Help
Does anyone know if the Xena model XZZ-6Y fits the pcx150? Even my dealer cannot answer, 6mm seems like it will but? don't need one that doesn't work for me! Really great site!
Re: Disc Lock Help
I've got the 6L and it fits. I think the body size of the lock is a bit larger than the 6Y, but they both have the 6mm pin.
- figurehead71
Re: Disc Lock Help
I use a Xena XX6 on my PCX, you definitely need a 6mm pin one for the disk brake.
Piercingly loud...main downside I find is fitting the battery and stealthfully trying to remove the damn thing..key poised at the ready making sure it goes into the lock barrel and turned in one swift movement else it will go off!
Re: Disc Lock Help
Agreed...I always feel like this when I'm taking off the lock:figurehead71 wrote:I use a Xena XX6 on my PCX, you definitely need a 6mm pin one for the disk brake.
