The Difficulty in Replacing Plastic Panels and Help Please
PCXWAX
Post by PCXWAX »
Hello All:
I bought a right side upper fairing piece for the PCX, as the original has a crack in it.
I have followed a few videos and a step-by-step on this site for removal. However, in the process, I started breaking plastic rivets and making things worse, so, I abandoned the project.
I had a HECK of a time for some reason putting the meter cover back on (two hours). I have included pictures, it is not seated properly and appears buckled. It looked sort of like this before I took it apart, but I think it looks worse. Do any of you have the same problem with your PCXs?
Does anyone have a video for reassembling the plastic parts? I see a lot of disassembly, and the manuals I am reading are a little confusing and difficult to read.
Anyway, I have included attachments of what is in front of me. Meanwhile, I am out four plastic rivets (does anyone have the part numbers for these?), I still have a crack in the fairing, and now I have a rattle in the dash!!
This is disappointing and a confidence blow. The dealer charges $160 per hour. I must admit, I have little patience and I do not want to destroy this scooter because I'm inept.
PCXWAX
Re: The Difficulty in Replacing Plastic Panels and Help Please
Post by PCXWAX »
Hello all!
Anyone have an idea on this one? Comments greatly appreciated!
PCXWAX
Post by PCXWAX »
**Update**
I have decided to bite the bullet and bring it to a dealer and have them put the panel on. I am hoping they can at least do a better job than I would have done, and perhaps will get the meter cover sorted out during that time.
Thanks all for reading my post.
airhead83
Year: 2025 US
Color: Pearl Gray
Post by airhead83 »
PCXWAX wrote: Mon Jul 22, 2024 3:03 pm **Update**
I see you got No replies or suggestions.
It's really difficult to describe where notches and tabs are located on these plastic panels, and how and in what order the parts need to be inserted and installed. Sometimes less said is better than steering somebody in the wrong direction... and less expensive if tabs are broken off beyond use.
Good Luck getting it all sorted out.
PCXWAX
Post by PCXWAX »
The dealer was able to replace the panel at a very reasonable cost and the bike looks great. Still having issues with the meter cover resting down and popping into place!
MikeRobert
Color: Matte Black
Post by MikeRobert »
Following this thread to learn.
2025
