Pcx Yuminashi Chainsaw 164!
Re: Pcx Yuminashi Chainsaw 164!
Must use copper gasket spray for the head gasket. That will stop and seal the head properly. If you're going in there constantly adjusting the gaskets because of the leaks, you got nothing to loose then to separate the gaskets and use single layer gasket, with copper spray on on sides of the gasket, the seal is perfect. This will also increase your compression slightly which you will very positively notice on the road performance. My head gasket never leaked or gave me issues once I used copped spray...
- Color: Gunmetal
Will have to try. Any recommended brand?Pcxdemon wrote: ↑Tue Apr 23, 2024 8:02 pm Must use copper gasket spray for the head gasket. That will stop and seal the head properly. If you're going in there constantly adjusting the gaskets because of the leaks, you got nothing to loose then to separate the gaskets and use single layer gasket, with copper spray on on sides of the gasket, the seal is perfect. This will also increase your compression slightly which you will very positively notice on the road performance. My head gasket never leaked or gave me issues once I used copped spray...
2019 Honda Click 125i
Yuminashi 164cc bore kit w/150 head
32mm throttle body and intake
13.5° SpeedTuner variator
15gr Dr. Pulley sliders
100/80-14(F), 120/80-14(R) Pirelli Angel Scooters
YSS front fork kit, YSS G-Series rear shock
As long as it's copper gasket spray I guess from a decent company, you should be good.
