I'm having trouble finding MCG for front tire (110/70 14), closest available options are 120/70 14 or 90/90 14 (keeping recommended difference below 3%). Will I have to modify front fender for 120/70 14? Not much or any availability of other tires in this size - other than stock IRC.
Will using 90/90 14 affect ride? Thanks!
						Replacement front tire 2021 PCX 150/160
- airhead83
 - Year: 2025 US
 - Color: Pearl Gray
Re: Replacement front tire 2021 PCX 150/160
I can't answer your question. But I have a website that allows you to plug in different tire sizes for a side-by-side comparison. I'm sure there are variations from different tire manufacturers, but the visual and other data this site provides is much better than an imaginary comparison.
Center Left across from the tire photo are two spaces... Tire Size #1 and Tire Size #2...fill them in and hit compare... the photo visually changes and gives height and width of the tires compared. Hope this is helpful.
https://tiresize.com/tyre-size-calculator/
I run 120/70 Front tire. Rides great..
When the rear is done, put a 140/70 in the rear.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
