roller weights
woutr73
Color: grey
roller weights
Post by woutr73 »
Hello everyone, first timer so nice to meet you all! Owner of a 2015 150cc since a good week now and really liking it so far. I have a question about roller weights.. My second hand pcx came with a non stock variator and two different roller weights, 12.5 and 10.5 gramms. The 12.5's make the pcx pretty fast from the start and the 10.5's, which are installed now, even seem a bit faster, however.. I wouldn't know how a stock pcx drives..
My question is, am I doing my pcx any harm with these roller weights? I think I read somewhere that the pcx in europe originally comes with 19 gramm weights? A quick acceleration is fun of course but I am wondering if I'm pushing limits here. Any helpful insight is highly appreciated!
ps.. I mostly drive in and around the city so acceleration is more important than top speed to me
Year: 18 300 xmax
Re: roller weights
You’re fine… All you’ve done is move the power band around to give you a little bit more acceleration. For a PCX 150 most people here have found the sweet spot to be the 13 g roller…
woutr73
Color: grey
Re: roller weights
Post by woutr73 »
That’s good news, thank you 👍🏻
mop3d
Year: 2022
Re: roller weights
Post by mop3d »
Does anyone know the "sweetspot" for the new 4 valve engine? the 157cc KF47 lowest roller weight without loosing top speed? Also stock size? dimensions and gram weight?
Conelite
Color: Blue
Re: roller weights
Post by Conelite »
I run 10.35g weight average. Get Great acceleration and retained my Top end 75+.
NCY variator, Dr pulley sliders.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Lou
Year: 1917
Color: Bronze Metallic
Re: roller weights
Post by Lou »
Does anyone know what size rollers a 2019 pcx 150 comes with stock?
Mprime
Year: 2021
Re: roller weights
Post by Mprime »
mop3d wrote: Fri Sep 23, 2022 9:38 pm Does anyone know the "sweetspot" for the new 4 valve engine? the 157cc KF47 lowest roller weight without loosing top speed? Also stock size? dimensions and gram weight?
While I can't answer this directly, I can tell you that I went with 18g Dr. Pulley sliders on mine. Noticeably quicker off the line and 2 mph gain on top end. Was looking to maintain 70 without bouncing on the rev limiter (71 top spd). Stock variator and Puig windscreen.
Stollies
Color: Grey
Re: roller weights
Post by Stollies »
I have a pcx150 2016 stock standard. What rollers without changing variator would you suggest and would I get a little bit more top speed.
Hobbit112
Color: Gunmetal
Re: roller weights
Post by Hobbit112 »
Try 12-14g, either standard or Dr. Pulley brand. Be sure to also replace the slides in the variator also.
2019 Honda Click 125i
Yuminashi 164cc bore kit w/150 head
32mm throttle body and intake
13.5° SpeedTuner variator
15gr Dr. Pulley sliders
100/80-14(F), 120/80-14(R) Pirelli Angel Scooters
YSS front fork kit, YSS G-Series rear shock
Conelite
Color: Blue
Re: roller weights
Post by Conelite »
Stollies wrote: Sat Jan 06, 2024 3:41 am I have a pcx150 2016 stock standard. What rollers without changing variator would you suggest and would I get a little bit more top speed.
You are not going to get much more top speed by just changing the weights. Changing weights only changes the shifting speed of the variator. You need a different Variator to get taller gearing for higher top end.
You might get an MPH or 2 by switching to Sliders but if you are already opening up the CVT, change the Variator.
2017 PCX 150
Wirus Win Exhaust
Z-Bars
NCY Variator
mandomfriman
Year: 2023
Re: roller weights
Post by mandomfriman »
Stock is 19grams.. You can use 18grams its good if lower the pulley dont have enouf weight for press up the belt.
