2012 PCX150 Valve Adjustment Tool?
Ralf_CT
Year: 2012 PCX150
Post by Ralf_CT »
Greetings!
I'm planning to buy some tools for a clutch/drive face bearing job on a PCX150, was also considering getting a valve adjustment tool, I see there are quite a few options.
1. Can someone please advise on the size of the locking nut and square adjuster?
2. What is the size of the holes in the drive pulley face (for the special tool pins)?
Many thanks.
Pearl White, 2012 Honda PCX150, 10,200kms, as at November 2025... and increasing slowly.
Ralf_CT
Year: 2012 PCX150
Re: 2012 PCX150 Valve Adjuster Sizes?
Post by Ralf_CT »
Can nobody assist with these questions, many have replaced the belt and set the valve clearances?
mymitzi
Re: 2012 PCX150 Valve Adjustment Tool?
Post by mymitzi »
Here is a link for an inexpensive home made clutch/variator tool............https://www.youtube.com/watch?v=YIVAimvORFI
Sorry.........can't help with valve adjustment but if you google 2012/2013 PCX valve adjustment .......you should get many hits.
pcx888
Color: pearl white
Post by pcx888 »
You need a tool like this. Image
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
