"Clunk" sound from front fork
op3l
Post by op3l »
So my PCX ever since new had this "clunk" sound whenever the front suspension compresses past a certain point. If I hold the front brakes and push hard down on the front forks, it will make the sound. The front suspension feels fine and aside from the annoying "CLUNK" every time I go over a bigger than normal bump.
Any idea what might be causing this clunking sound and if it's an easy fix?
power-full
Year: 2010
Color: preta
Re: "Clunk" sound from front fork
Post by power-full »
Hello, good morning, mine also presented this noise the question was that the oil of the suspension had never changed and was about 65 thousand km, when I dismantled a small clearance on the bush / guide, I bought new in the Honda and it was as new so far at 93000km. 😃
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
steering head bearings ?
power-full
Year: 2010
Color: preta
Yorkie150 wrote: Sun Apr 03, 2022 5:02 am steering head bearings ?
if it was the bearings I would always do it.. in general it's the bushings... it can come with a defect.. is it under warranty? if yes, make a complaint...
op3l
Post by op3l »
I'm not sure what it might be, it's like a metallic clunk like metal hitting metal. I can't feel the clunk in the handle bar either, only hear it. The front forks have gotten pretty soft after 11k KM, think the problem might go away if I get the fork oil changed?
