Speaker wiring
- Year: 2012
Speaker wiring
I need help wiring my speakers to the bikes ignition so they come on when I turn on the ignition.
Re: Speaker wiring
Why? If you have a problem starting the bike, you certainly don't want to have to contend with additional connections that could be contributing to the problem. Connect it so that you just flip a switch after the bike has started and you will have less problems later on. I have several things wired through relays that kick in once I through a switch. Much simpler and no fear of burning out anything from a sudden surge in electricity.
