pcx power-full
Valeriy7
Year: 2012
Re: pcx power-full
Post by Valeriy7 »
power-full wrote: Sat Feb 12, 2022 2:31 am the gasket must always be new. because the joint comes with a height to be crushed when it is tightened that's what makes the seal.
when assembling the new gasket you must start the motorcycle for 5 to 10 minutes stopped in place to warm up the engine and open the thermostat, to picture the circuit. I usually do it like this: I fill the radiator with antifreeze, put the radiator cap on (be careful it cannot be the original cap which is 0.9 bar, it has to be 1.6 bar) I start the bike at idle, then I start accelerating around 30/40 Kh or so and I'm putting my hand on the down tube that comes to the radiator (be careful not to touch the exhaust tube) when the radiator tube starts to get hot turn off the engine. after about 30/40 minutes, open the radiator cap, refill the level as needed (almost always accurate), put antifreeze in the expansion vessel and good curves....
Thank you very much! I have done this before with the lid open, adding gas until air bubbles come out. Lid 1.6 bar.
power-full
Year: 2010
Color: preta
Re: pcx power-full
Post by power-full »
you shouldn't do it with the lid open that works fine on big circuits not here on this one so small..
Valeriy7
Year: 2012
Re: pcx power-full
Post by Valeriy7 »
power-full wrote: Sun Feb 13, 2022 4:49 am you shouldn't do it with the lid open that works fine on big circuits not here on this one so small..
Thanks! I'll be taking the engine apart soon. We still have frost and snow, waiting for the heat.
ToraxOutlaw
Year: 2012
Re: pcx power-full
Post by ToraxOutlaw »
Where did you get the LED headlights and sidelights from?
power-full
Year: 2010
Color: preta
Re: pcx power-full
ToraxOutlaw wrote: Mon Feb 14, 2022 4:05 pm Where did you get the LED headlights and sidelights from?
comprei no ebay..vou ver se consigo o link.
https://www.ebay.com/itm/255303776596?h ... SwJ1dhzJCZ
power-full
Year: 2010
Color: preta
Re: pcx power-full
hello guys here are some more pics
original vs leds
original vs leds
ToraxOutlaw
Year: 2012
Re: pcx power-full
How would you connect the H4 bulbs to the HS5 sockets?
power-full
Year: 2010
Color: preta
aRe: pcx power-full
you cut the plug before the socket you leave a little wire for if one day you want to assemble it again, and you have the connections there .. you pass a medium wire to each side and the same with the medium wires
ToraxOutlaw
Year: 2012
Re: pcx power-full
Brilliant. Thanks.
ToraxOutlaw
Year: 2012
Re: pcx power-full
I don't fancy cutting and splicing wires. Are the any kits around that'll convert HS5 to any other bulb type?
ToraxOutlaw
Year: 2012
Re: pcx power-full
I'm only asking this as the LEDs you have installed are not road legal for the UK. My bike would fail its MOT.
power-full
Year: 2010
Color: preta
Re: pcx power-full
Yesterday was such a weird day. belt had 2000km, all of a sudden on the highway it was like this... I'm back on the road but this time only with 120 kh... I'll have to buy some new parts from yuminashi.
power-full
Year: 2010
Color: preta
Re: pcx power-full
Aos 94000km
power-full
Year: 2010
Color: preta
Re: pcx power-full
Hello good morning .. this weekend I started assembling the new yuminashi 164cc v2 kit here are some of the photos ..
mymitzi
Re: pcx power-full
Post by mymitzi »
Nice clean up...........will you replace with a Honda Belt or have they not been up to the task? Hope you get er going soon.
power-full
Year: 2010
Color: preta
Re: pcx power-full
Good Morning. a yuminashi 164cc version 2 kit was assembled. this kit is fitted to 2010 engines up to 2018 engines .. in the non-esp version it is necessary to open the engine casings. an injector is included, I already gave a brief description of what will come out of here.
power-full
Year: 2010
Color: preta
Re: pcx power-full
mymitzi wrote: Mon Apr 25, 2022 9:03 am Nice clean up...........will you replace with a Honda Belt or have they not been up to the task? Hope you get er going soon.
Hi i mounted one of Polini. I have another one of these from gates for this new kit.
power-full
Year: 2010
Color: preta
Re: pcx power-full
Firts video to kit 164cc v2
https://youtube.com/shorts/JmoE02PC8q0? ... tube]share[/youtube]
dankly1
Color: Silver
Re: pcx power-full
Post by dankly1 »
power-full wrote: Wed Apr 13, 2022 12:04 am Yesterday was such a weird day. belt had 2000km, all of a sudden on the highway it was like this... I'm back on the road but this time only with 120 kh... I'll have to buy some new parts from yuminashi.
Any idea what part or parts failed and caused the problem with your variator? Did one of the rollers come apart? Thanks!
dankly
2019 PCX150
2013 Yamaha FJR1300
1983 Suzuki FA50
Iron Butt Association #80052
power-full
Year: 2010
Color: preta
Re: pcx power-full
hello good morning guys. I already have the new videos of the new kit assembled on my YouTube page. here is the last yesterday made just for walking I will have to adjust the weights of the variator
https://youtube.com/shorts/f8TzqPll_jA?feature=share
https://youtube.com/shorts/_U4cts3kxfk?feature=share
