dr pulley rollers / sliders
150pcxer
Color: Silver
Re: dr pulley rollers / sliders
Post by 150pcxer »
Hi all,
I just installed the Dr Pulley sliders, 14.5 grams, as recommended by the workshop.
However, I noticed there is this sound. Is it normal? Or is something wrong?
What's the cause of it?
Thanks.
Conelite
Color: Blue
Post by Conelite »
Im sure its fine. If it runs fine and shifts properly, it will be ok. They are sliders so the odd shape can cause some to rattle around at idle. If you are worried, take it apart and make sure you installed the sliders correctly. BTW I would recommend going lighter. 12-13g sliders is much better.
150pcxer wrote:Hi all,
Thanks.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Pcxdemon
Post by Pcxdemon »
Dr pulley sliders last very long time without any wear so performance will not detoriate due to wear unless its belt that is worn. So, that alone is worth upgrading to sliders. Ive had mine for a long time and when I step down to rollers, I feel I've also stepped down in performance (weight for weight between the two), so that makes it two reasons why everyone should just use sliders.
150pcxer
Color: Silver
Post by 150pcxer »
Conelite wrote: Thu Dec 10, 2020 11:49 am Im sure its fine. If it runs fine and shifts properly, it will be ok. They are sliders so the odd shape can cause some to rattle around at idle. If you are worried, take it apart and make sure you installed the sliders correctly. BTW I would recommend going lighter. 12-13g sliders is much better.
Pcxdemon wrote: Sun Jul 04, 2021 6:37 am Dr pulley sliders last very long time without any wear so performance will not detoriate due to wear unless its belt that is worn. So, that alone is worth upgrading to sliders. Ive had mine for a long time and when I step down to rollers, I feel I've also stepped down in performance (weight for weight between the two), so that makes it two reasons why everyone should just use sliders.
Just replaced these Dr Pulley sliders. They were used for only 15,000 km (9320 miles).
Do they look worn out to you?
Year: 26 adv 160
no………………..
150pcxer
Color: Silver
Post by 150pcxer »
Jge64 wrote: Fri Nov 26, 2021 11:26 am no………………..
to me, they were worn out after using them for 15,000 km.
i had to replace the sliders as the revs were getting higher than usual.
Year: 26 adv 160
Then why did you ask?
150pcxer
Color: Silver
Post by 150pcxer »
Jge64 wrote: Thu Dec 02, 2021 9:50 am Then why did you ask?
because i exactly knew my rollers were worn out
and that's why it conflicted with what many of you thought about D.P sliders, that they were long-lasting. I asked to seek further clarification, if any one else on this forum had experienced anything similar to mine.
Conelite
Color: Blue
Post by Conelite »
You should be changing your weights maybe every 5k miles. Them and maybe a belt. Cheap insurance to optimize performance.
2017 PCX 150
Z-Bars
NCY Variator
Hobbit112
Color: Gunmetal
Post by Hobbit112 »
150pcxer wrote: Fri Nov 26, 2021 11:53 am
Pretty good mileage if you ask me.
My last set of regular NCY rollers only lasted 6,000 km before they were worn to the brass core in spots.
2019 Honda Click 125i
Yuminashi 164cc bore kit w/150 head
32mm throttle body and intake
13.5° SpeedTuner variator
15gr Dr. Pulley sliders
100/80-14(F), 120/80-14(R) Pirelli Angel Scooters
YSS front fork kit, YSS G-Series rear shock
Pcxdemon
Post by Pcxdemon »
Probably your belt was worn out, got skinnier hence your increased revs and would have less top speed. 15000 on a belt is great but performance suffers. Sliders would have been fine.
Jacito
Post by Jacito »
Has anybody tried a NCY Variator with Dr Pulley sliders? Is it even possible?
Jim
'15 Honda PCX 150
Pearl White
Motori Tec Inc. Performance Variator w/ 14g rollers
ContiScoot tires - safety recalled
Avon Viper tires
Chip1wa
Year: 2022
Post by Chip1wa »
For the '21 PCX/157cc engine, the stock rollers are 20mm x 15mm 19 gram rollers. Recently I installed the 20mm x 15mm 13gram Dr. Pulley sliders into the stock variator and I saw a 65mph indicated top speed. Has anyone installed the 21 x 15mm 13gram Dr. Pulley sliders?
Hobbit112
Color: Gunmetal
Post by Hobbit112 »
Chip1wa wrote: Mon May 29, 2023 8:55 am For the '21 PCX/157cc engine, the stock rollers are 20mm x 15mm 19 gram rollers. Recently I installed the 20mm x 15mm 13gram Dr. Pulley sliders into the stock variator and I saw a 65mph indicated top speed. Has anyone installed the 21 x 15mm 13gram Dr. Pulley sliders?
Did you hit the rev limiter? Seems a bit slow. I was hitting that with a stock Click 125i and 13gr Dr. Pulleys.
With a bore up to 164cc (plus other upgrades) easily hit 70+ with 15gr Dr. Pulleys.
