Scooter cranks but does not start (sometimes)
geovie
Year: 2020
Color: Grey
Post by geovie »
Hello, I am George and Ι have a PCX 125 MY18 that I bought in August 2020. It now has 4100km and I never had a problem and really enjoyed using it.
A month or so ago it started to act weird. At first, it needed to crank a few times to start the engine which it never did before, it was starting as soon as I pressed the button. I didn't give it enough thought since it happened 3/10 times. When it did this after eventually starting up I opened the throttle, it revved up a bit started to move then revved down(on its own). After that, it continued to operate normally.
At first, I thought it might be a problem with the gasoline so I filled up with the best fuel I could find. After the fill-up, it stopped acting up. 10 days after the fill-up, I used it for a bigger than normal trip and on my way back it refused to start. I cranked it close to 10 times and turned the key between tries but it would just crank and not start. I loosened the back brake and tried to "push start" it while also holding the ignition. My attempt was successful and I managed to start it and get back home. Since then it had started to act up again as it did before.
Because this isn't always happening I am afraid that if I take it to the dealership they will tear down the scooter not find anything and just waste everyone's time.
Has anyone had a similar problem?
What could be the cause or are there any other signs I should look for?
Thanks for reading this and sorry for my English! :D
mymitzi
Re: Scooter cranks but does not start (sometimes)
Post by mymitzi »
English is fine..........Agree about the dealer.........intermittent problems : { Surprised you could push start it. Can you test the battery?
If it checks healthy............a loose connection on the battery sometimes can cause what you are describing.
power-full
Year: 2010
Color: preta
Post by power-full »
Good Morning. I had something like that... it would catch on and it was barely slow and even then it would go down...change the tow bike home and start doing a test... I always thought it was the gas pump... when I went to see the injector was completely clogged .. it was just clean and so far I have never had any stress.
gas pump before washing,
geovie
Year: 2020
Color: Grey
Post by geovie »
mymitzi wrote: Sat Jul 10, 2021 11:02 am English is fine..........Agree about the dealer.........intermittent problems : { Surprised you could push start it. Can you test the battery?
Thanks for the reply! I have checked the battery and it tests good. I was also surprised with the push start and I have now done this twice.
geovie
Year: 2020
Color: Grey
Post by geovie »
power-full wrote: Sun Jul 11, 2021 2:50 am Good Morning. I had something like that... it would catch on and it was barely slow and even then it would go down...change the tow bike home and start doing a test... I always thought it was the gas pump... when I went to see the injector was completely clogged .. it was just clean and so far I have never had any stress.
Good morning to you too! Yes, I am also suspicious of the gas pump but I know that usually the gas pump either works or not. A clogged injector checks with the fact that I was able to push start it. Maybe the "extra" vacuum in the cylinder managed to pull gas through the injector. I have to disassemble half of the scooter to get to the injector, don't I?
power-full
Year: 2010
Color: preta
Hello good Morning . here is the video I made to test the gas pump. as I saw that it was good, I changed the butterfly and the complete injector... the bike was immediately good.... so I went back and changed it by phases. (I changed the body of the butterfly (I assembled the original), and the tube was fine, I changed the injector (original) and we have gutters again... that is, it was my problem.... when I looked with eyes to see is that I noticed that the injector network was not visible ..hence these photos ....
Video
https://youtube.com/shorts/K76iH_T3Rac?feature=share
geovie
Year: 2020
Color: Grey
Post by geovie »
For any future visitors. Hello!
I looked at the injector and it looked ok. I didn't look at the fuel pump mainly because the tank was REALLY full and gas would spill everywhere. I will post if there is any update.
geovie
Year: 2020
Color: Grey
Post by geovie »
It finally died and I took it to a workshop. They told me that it was a fuel pump issue and they replaced the fuel pump under warranty. It's running fine ever since. Hope this helps someone in the future.
