Kick stand spacer/ pad
ghmpm
Color: red
Post by ghmpm »
One small gripe I have with my 2015 Forza is the kickstand. the foot is very small and bike feels unstable at times using it. I had the same problem on my Silver Wing so I bought a kickstand pad for it. Major change! Bike is not near as unstable and kickstand is good even in dirt or gravel. Here is the link for 2013-2017 Forzas. From China but price is good and it works!!!
https://www.ebay.com/itm/283494101453
One caveat, when installing use some loctite on the bolts, mine came loose and I nearly lost it. Using loctite eliminated the problem.
Cao.
Glenn
2015 Honda Forza 300
2012 Honda Silver Wing
2005 Honda Goldwing Trike
davenowherejones
Color: Silver
Re: Kick stand spacer/ pad
Post by davenowherejones »
Never had a problem in 144,000 km but I actually look where I park my scooter.
davenowherejones wrote:Never had a problem in 144,000 km but I actually look where I park my scooter.
It'll be on the ground won't it?
Austins
Year: 2016 Forza 300
Post by Austins »
I too have to double check sometime...Here I go to the beach a lot so sometime there's sand and gravel or uneven surface, it's not a 1st world country with perfect roads you know (! lol), so I think something like this will be useful, I put it on the wish list... , thanks for posting.
Old Scoot
Post by Old Scoot »
If he's lucky, otherwise in a tree :lol:
davenowherejones
Color: Silver
I had a Suzuki DR650 dual sport before the Forza. I lowered it for my 5 foot 6 body.
It is recommended to buy a shorter side stand because it would tend to be almost straight up. Very unstable.
Some people cut a bit off and re-weld the pad back on.
I found and even easier method.
I took a 20 pound hammer and bent the side stand until it had a good lean.
Problem solved. It stuck out a bit but no more than my fat ass.
davenowherejones
Color: Silver
Not yet but I have had to pick a good rock to put the side stand on once or twice.
I usually give it a good shake before I leave.
Not yet.
:lol: :lol: I can't beat that :lol: :lol:
Austins wrote:I too have to double check sometime...Here I go to the beach a lot so sometime there's sand and gravel or uneven surface, it's not a 1st world country with perfect roads you know (! lol), so I think something like this will be useful, I put it on the wish list... , thanks for posting.
Get an aluminium pop can. Stand on the top and squash it flat. Pop it under the side stand. Sorted.
Keep or repeat.
Old Scoot
Post by Old Scoot »
A piece of plywood about 10 x 10 cm [4"x 4"] and about 1 cm [3/8"] thick will also do the trick and you can easily store it under the seat
ghmpm
Color: red
Post by ghmpm »
I have a metal pad about 3.5 inches around that I carry and use in very dicey conditions (try not to get in those). But the kickstand pad works for most conditions. If you are happy with yours as is then just ignore my post...
Glenn
ghmpm
Color: red
Post by ghmpm »
Here is a picture of the one on my Silver Wing (very similar). My Forza is 300 miles away atm.
Glenn
davenowherejones
Color: Silver
I don't have a kickstand pad but I definitely approve using one.
I see the need for one as proof that the motorcycle was designed wrong.
Should everyone buy one before a coffee cup holder, or after?
davenowherejones
Color: Silver
I have a really expensive coffee cup holder, it's a Dodge Dakota 4WD. Damn expensive holder.
Old Scoot
Post by Old Scoot »
davenowherejones wrote:I have a really expensive coffee cup holder, it's a Dodge Dakota 4WD. Damn expensive holder.
:lol: :lol: :lol: :lol: :lol:
MBMyer
Post by MBMyer »
I’ve been using one of those on this bike since 2015. Don’t have to keep up with a soda can or other type of toss-down pad. And given some of the places that I park my poor, abused steed, this has been a necessity.
6 other previous bikes
