Hello everybody,
My pcx 125 stops when i was riding.
He didnt want to start anymore.
By turning the contact:
Km counter turns from left to right.
Odometer background is orange, but no fuel or km info.
I already did replace the battery.
What can the problem be?
Ecu error?
Thank you for so far.
Honda PCX 125 stops while riding. Elektric problem?
Re: Honda PCX 125 stops while riding. Elektric problem?
Check the battery terminals are tight, then check the earth strap, check any fuses are in properly, then work your way around the loom looking for any bare spits or breaks, check connectors
Sent from my SM-G930F using Tapatalk
- easyrider
- Color: blk
Good advice... double check ground connections look at all connectors around computer for looseness , dirt etc for clues. Disconnect then reconnect all connectors.RuffStuff wrote:Check the battery terminals are tight, then check the earth strap, check any fuses are in properly, then work your way around the loom looking for any bare spits or breaks, check connectors
Damaged wire?!
- Gil
I have had this issue once. It was the red emergency engine stop switch on the right handlebar. Flicked it back and forth a few times and it started again. Might not of been your issue, but it might help someone.
![Image](http://badges.fuelly.com/images/sig-us/553752.png)
![Image](http://badges.fuelly.com/images/smallsig-metric2/553752.png)
Doogee here in Atlanta, Georgia USA.They are right about the kill switch. This is the neighbor's wife scoot the battery died on them years ago and he tried putting a new battery in there and it did not start again so it set in their garage. Now it's getting warmer here they want to ride.I noticed some mice that been chewing on the wires right by the fuse box. Well to check for further rodent damage I took all the Tupperware off.No other damage. I'm not that familiar with these but when you turn the key on the check engine light would not come on fuel pump would not run but had turn signals and Horn and brake lights. I researched the internet and found some people having intermittent starting problems. I tested the brake switch and the kickstand switch and they were okay.I think this is where the no start is coming from if your check engine light does not come on with key on. I jumped the switch and all is good. He ordered a new switch from partzilla.com number 3 5 1 3 0 - k wn-671 labeled as switch unit, engine stop for $11.09 haven't got the part yet but the picture looked right. Hope this helps.
Yes, common problem. WD-40 would have worked temporarily. The Kill switch gets water in it and then you have all sorts of weird problems.
As for the mice, yes, they like bikes. When I bought my PCX it didn't make it home before it started having light problems in the back. I took it apart once I got it inside and found a mouse nest made out of pretty colors...The rear wire covers. I took it back to the dealer and they had to replace the wiring harness section in the back, after removing the mouse nest. Mice weren't happy, but I was.
