so i installed this (see pic) 40 litre box, and it's causing tank slap even when empty.
anyone else experience this or have this box?
anyone else have this box??
pcxthai150
- Year: 2020
- Color: red
- IMG_20200728_004551.jpg (391.5 KiB) Viewed 1478 times
Re: anyone else have this box??
Is that 40 liters?
pcxthai150
- Year: 2020
- Color: red
yes. 40 litres
pcxthai150
- Year: 2020
- Color: red
was anything you just said, supposed to be helpful or useful information??
This is the second time I have read of someone putting a large tail box on their bike and then dealing with stability problems. It seems that some of the no-name tail boxes are not tested on the bikes before production. It is possible that the aerodynamics of that box destabilizes the air as it passes over and around the box.
My suggestion would be to test a name brand tail box on your bike to see if it causes the same problem. (The base plate should be universal, so it should not be difficult to swap boxes.) The PCX has gone through some major design changes in the last few years. Some of those changes could affect the aerodynamics. Keep in mind that the newer bikes do not have a wide choice of tail boxes yet, possibly because of that problem.
pcxthai150
- Year: 2020
- Color: red
hmmmm.....yes. thank you. much to think about indeed.
well i appreciate the feedback very much.
thank you
thank you
