Topbox instead of pillion seat?
Hassan
Year: 2020
Color: RED
Post by Hassan »
Hi All, I currently own a PCX 125 2020, and bought it blind and didn't consider the pillion seat to be so big compared to a 50cc bike. Instead of adding a topbox on to the body and making the body length longer, I was thinking of adding a topbox to the pillion seat but haven't found any online. Is this possible? and if you have seen any online could you link them, please. I'm in the UK.
Honda PCX 125 (2020) RED
Manchester, UK
RuffStuff
Year: Na
Color: N.a.
Re: Topbox instead of pillion seat?
Post by RuffStuff »
Food delivery racks sit half over the rear seat, check ebay
Sent from my SM-G930F using Tapatalk
Gil
Post by Gil »
RuffStuff wrote:Food delivery racks sit half over the rear seat, check ebay
They do, the ones I have seen use two pieces of plywood with a piano hinge. That way you can just lift the box when you need to access the under seat storage.
RuffStuff
Year: Na
Color: N.a.
Post by RuffStuff »
Also metal ones about that work on a similar idea, any small engineering place could knock one up tbf.
RuffStuff
Year: Na
Color: N.a.
Post by RuffStuff »
https://www.ebay.co.uk/itm/153450168573
MikeP
Color: White /red
Post by MikeP »
How about a BBQ instead of a pillion seat?
My latest project for my day trips. Finally perfected the mounting board, in the process of finishing it.
dgnyberg
Post by dgnyberg »
I didn't like the look of the rack and box sitting out in mid air behind the scoot. So, I use two straps to hold my top box to the pillion. I cut two sliced on the seat base and run the strap through those holes to keep the box from moving around. It's not permanent and the box becomes a back rest for me. When I raise the seat, the top box goes up with it.
_____________________
Dave
KG5VOO
This might be of interest
viewtopic.php?f=7&t=1900&p=27015
