Electric supercharger install
Conelite
Color: Blue
Re: Electric supercharger install
Post by Conelite »
Jge64 wrote:I was always under the impression that either with nitrous, or a super or turbo charger, that the bottom end of an engine had to be fortified before it was viable… (With forged components) Can the PCX take the bottom end load?
Thats a myth. I work for a pretty reputable Performance parts Manufacturer. We specialize in Positive displacement Blowers. Newer vehicles come much stronger from factory.
We have pushed 12-15psi of boost on stock bottom end V8s with no real issues (Granted you have to upgrade all your fuel system to keep up, even more of you want to run on corn juice).
The issue with these E-Superchargers is its not a supercharger at all. Its a Fan. It pushes air, it doesnt compress it. Only way I see this working at all simply being that at LOW rpm the engine is moving very little air and causes there to be some kind of boost in from the intake valve to the fan but once you the engine is up in the RPM range it will equal out. Not to mention the power draw on the system.
If the stock ECU cant compensate for open air filter and exhaust, Its certainly going to run lean and you will risk knock, and at worse you bust a ring land or something..
But I look forward to the results. Popcorn in hand.
Gil wrote: It depends on how strong the engine was designed to be. All engine have a limit on how much extra HP can be made with OEM internals, some more than others. Only way to find out is to try it. No one here has done a turbo on a stock internal of Honda PCX engine, or a turbo for that matter.
Coming from the Ruckus Scene, Couple people tried Turbo on GY6 150cc engines. Not enough air to actually spoon even the smallest turbo.
Standard Functions did a Zume 125cc swap into a ruckus. Bored it out to something over 200cc and made a couple PSI of boost.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Gil
Post by Gil »
"Coming from the Ruckus Scene, Couple people tried Turbo on GY6 150cc engines. Not enough air to actually spoon even the smallest turbo.
Standard Functions did a Zume 125cc swap into a ruckus. Bored it out to something over 200cc and made a couple PSI of boost."
Thanks very cool, I wonder what turbo they used? The few project that I have seen online have also only produced a few PSI of boost.
Conelite
Color: Blue
Post by Conelite »
Mikes150pcx wrote:Let me just add that the volume-metric efficiency should improve and that equals power.
How is the S/C PCX coming along?
Any updates?
2017 PCX 150
Z-Bars
NCY Variator
Mikes150pcx
Color: Metallic grey
Post by Mikes150pcx »
ITS A FRAUDULENT, DON'T BUY IT! I SHOULD HAVE KNOWN!
Limey
Year: 16 Forza/16 PCX
Color: Red/Maroon
Post by Limey »
Mikes150pcx wrote:ITS A FRAUDULENT, DON'T BUY IT! I SHOULD HAVE KNOWN!
Well, Duh!!!! :lol: :lol: :lol: :lol:
Gil
Post by Gil »
Properly engineered turbos, plural, do work if you know what you are doing. Checkout this project out, a turbo compound 125cc salt lake racer motorcycle. Custom turbos were used to get the 45 psi of boost the owner wanted. He is pushing 60 RWHP.
https://www.facebook.com/POST100
http://post100.com.au/the-motor/
http://post100.com.au/development/
Gil
Post by Gil »
14 PSI with a single turbo, he is getting 28 hp. Look at that custom exhaust turbine housing.
https://www.facebook.com/POST100/photos ... 320498042/
Gil
Post by Gil »
Here is a post on the size of the turbo.
https://www.facebook.com/POST100/photos ... 139808127/
15781318_736839139808127_8839480254177142230_n (1).jpg (107.47 KiB) Viewed 4389 times
Gil
Post by Gil »
One last post. This one graph is of the stock Garrett GT06 turbo and the one with the custom turbine exhaust. The stock Turbo seems to be just right for the RPM range that our scooters run at.
https://www.facebook.com/POST100/photos ... 863442258/
Blue line is the stock GT0632.
