Anybody know where '13 speed sensor plug is located?
ScottDR
Post by ScottDR »
Hi all!
I bought a 12 Oclock Labs speedometer adjuster and am hoping to install it soon.
Anyone?
Thank you!
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
1986 Kawasaki Ninja 250r
Inoplanetyanin
Year: 2018
Color: WHITE
Re: Anybody know where '13 speed sensor plug is located?
Post by Inoplanetyanin »
Sorry, have no idea what that is, how it works or why would you need it.
ScottDR
Post by ScottDR »
Well, I see in the wiring diagram that there are at least 2 plugs. Anyone know where one can be accessed?
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
Gil
Post by Gil »
It's located on the rear final reduction gear, just behind the rear shock and under a plastic guard. The arrow in the picture.
ScottDR
Post by ScottDR »
Thanks Gil! Is there a matching electrical connector for it at any other point up to the gauges?
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
Gil
Post by Gil »
I don't think their is another spot on the wiring harness where you could splice it in. If it's like the one on the picture, then you could tuck the water sensitive part of the adjuster at a dryer spot. Probably by the throttle body.
Has a long wiring harness, so you should be able to mount it on a dry spot.
ScottDR
Post by ScottDR »
Ok, thanks. Yes it has a pair of matching connectors(in and out) for the sensor.
Cheers!
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
