Need Help Installing the Seat Spring
scootindude
- Color: blue
I removed the seat on my 2017 PCX 150 and I can't figure out how to put the spring (that holds the seat up) back in properly.
Re: Need Help Installing the Seat Spring
Maybe a visual of my 2015 seat hinge/spring will help?
- image.jpeg (84.47 KiB) Viewed 2647 times
- image.jpeg (130.73 KiB) Viewed 2647 times
- image.jpeg (193.55 KiB) Viewed 2647 times
- image.jpeg (178.33 KiB) Viewed 2647 times
- image.jpeg (109.67 KiB) Viewed 2647 times
Oh, and Welcome to our forums
Do us a favor please, add your location to your profile. Easy directions to complete yours is right below my post. Thank ya!
- Limey
- Year: 16 Forza/16 PCX
- Color: Red/Maroon
Mine looks like this:
They have a spring?? Does the 2013 model have a spring? I've never noticed a spring, and I take my seat off at least once every couple of months. What is it for?? My seat falls all by itself if I don't tie it up, but that is gravity.
- Limey
- Color: Red/Maroon
My 2013 didn't have a spring and would not stay up unless I leaned it against the front. However my 2016 does have a spring. In my picture it is the wide shiny thing that passes under the cross member with the two bolt heads.Mel46 wrote:They have a spring?? Does the 2013 model have a spring? I've never noticed a spring, and I take my seat off at least once every couple of months. What is it for?? My seat falls all by itself if I don't tie it up, but that is gravity.
scootindude
- Color: blue
Thanks, That Helps.scootindude wrote:I removed the seat on my 2017 PCX 150 and I can't figure out how to put the spring (that holds the seat up) back in properly.
ChuckD
- Color: Blue
Thanks, WhiteNoise!
Note to self: Photograph everything before disassembly!
2017 PCX150
