rear grab rail metal top plate
johnyrrr
Color: red
Post by johnyrrr »
Does anybody make a metal/aluminum top plate that mounts directly to the rear grab handle bracket? Also how do you remove the plastic cover that covers the entire grab rail without breaking tabs?
davenowherejones
Color: Silver
Re: rear grab rail metal top plate
Post by davenowherejones »
Open the seat. There are two plastic rivets by the body panel. Push in the centers. Pull out the rivets. The back cover should now be removable. Pull gently. The body panel has markings on the back of it where you need to drill holes if you intend to put the panel back on.
http://giviusa.com/my-motorcycle/honda/ ... ack-detail
Has the details.
Make sure you know the difference between monokey and monolock boxes/racks.
You can also just use long bolts & spacers and use the holes in the Forza frame to make your own mounts.
Givi is really confusing, I hate their names, really expensive also.
I have a 55 liter box on for the last 100,000 km. It is wide but so is the Forza. And so is my ass so it all works out OK.
