How-To: Convert 2013 to LED superbright headlight
RobV
Year: 2012
Re: How-to convert 2013 to LED superbright headlight
Post by RobV »
The LED ones are quoted as 50W or 80W. Is that the power consumption or the halogen equivalent? I would expect a 30W halogen to put out about as much light as a 10-15W LED. I've had issues with past bikes burning out ignition switches because power to the headlights went through the ignition switch. Thus I thought a 20W LED would give me more light for less power. I'd expect an 80W LED to give me as much light as a 150W halogen - more than I need.
power-full
Year: 2010
Color: preta
Post by power-full »
hi. on my pcx of 2010 I used led h4 lo / hi at 2 headlights, 6500k, 8000lms, 36wts, I have a very beautiful and strong light compared to the originals, could give light farther (farther from the bike)
I have to put the photos by the pc, because here by the application I'm not getting
Enviado do meu 6055K através do Tapatalk
power-full
Year: 2010
Color: preta
hello now here are the photos ..
H4 6000LM 35W 6000K Led
upload_-1 (1).jpg (102.91 KiB) Viewed 45212 times
upload_-1 (2).jpg (67.57 KiB) Viewed 45212 times
How did you adapt the connector?I believe that the non-life version of the PCX has HS5 bulbs. I am interested in converting mine. I already swapped the original bulbs for better quality ones with better light output, but led headlights would be much better.
power-full
Year: 2010
Color: preta
hi. I bought the lamps in h4, in this type of lamp, the plate that makes (h4, h7) is screwed, just remove it, you can see in photo number 2, ie mounted without the plate,.
pcx888
Color: pearl white
Post by pcx888 »
how did you prevent the h4 bulb from falling out.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Adamyo
Color: red
Re: How-To: Convert 2013 to LED superbright headlight
Post by Adamyo »
Unfortunately link is broken. Can anybody share it? Thanks!
