Newbie
FORZY
Color: Black Forza
Newbie
Post by FORZY »
Hello everyone
Thought I'd join up and say hello
I have a 2019 Forza 300 with a few accessories :D
My 2019 300
My 2019 300
FORZA 1.jpg (402.89 KiB) Viewed 3614 times
2019 Forza 300
Year: 26 adv 160
Re: Newbie
Why don’t you tell us about your accessories?
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
Ok
Some don't show in photo, I'll try and get an updated one
GIVI SCREEN
GIVI HAND GUARDS
TOMTOM RIDER 550
YSS FRONT FORK UPGRADE KIT
HONDA INTEGRATED HEATED GRIPS
HONDA INTEGRATED TOP BOX
SIDE STAND FOOT ENLARGER
AIR HAWK CUSHION
2019 Forza 300
springer1
Year: 2018
Re: Newbie
Post by springer1 »
I wish they were sold in the states
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
springer1 wrote:I wish they were sold in the states
Could you get one imported ?
2019 Forza 300
Year: 26 adv 160
Re: Newbie
When you import to the us, you have problems in many states with registration, warrantee is affected, and parts supply may not be 100%…
smoothOperator
Re: Newbie
Post by smoothOperator »
Hi @Newbie, and welcome to the forum,
1. How is the front fork upgrade. Is it softer with the YSS when driving over small road bumps or small potholes, or is is even harder/stiffer?
2. The windshield: Is it fix, or still adjustable in height? When driving on bad roads, does it rattle the same as the original?
3.The AIR HAWK CUSHION. There are several styles/models. Which one do you use. I'm worried the seating position could get too high and it could be difficult to get my feet on the ground as the forza seat is pretty wide. What is your expirience with that cushion at all?
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
Thank you
1. Firstly, I am a heavy bloke and the standard forks are pants city to put it politely. Mine sagged when sat on and, I'm sure, bottomed out too easily, causing severe jarring. Not good for me or the bike. Also, they were becoming worse quickly, they had to be sorted
The upgrade has improved things a lot. It now sags very little with my weight. It doesn't dive so much, and not bottomed out at all so far and the ride is much improved
I have only fitted this recently, so only done a couple of rides so far, but, I am confident they are a definite improvement
2. The GIVI windscreen is still fully adjustable. With it set right down, it is about as high s the original at its highest, therefore, is approx 4 inches (100mm) higher than the original, when raised. Also the GIVI is a little wider too
I don't recall any rattling with the GIVI or the original.
3. It is the Cruiser Medium, seems the perfect size. Only let down is the straps and cover, but, IMHO, its better overall
You can go further before the posterior hurts, before the barrier was about 50 miles. I find it increases the ride height very slightly, but, I find that actually helps my legs feeling quite so cramped. My feet still reach the ground, one side might be more on tip toe. If you want to do distance its worth having imho
2019 Forza 300
smoothOperator
Re: Newbie
thanks for the reply, i will go for the Airhawk, as i am doing a lot of long distance trips.
i am still looking for a more convenient suspension. Which suspension for the Forza 2018 feel soft and cosy like that one of an Africa Twin. Such a sofa feeling on the Forza would be the perfect bike.
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
Of course its up to you, but, the YSS kit has adjustment and you could leave the spacer out and or put in lighter oil etc
Look it up, the other option if the expensive Ohlins kit
2019 Forza 300
Deksx
Year: 2018
Re: Newbie
Post by Deksx »
Hi Forzy,
I like the look of the sat nav. Did it come with the mounts or did you have to find these elsewhere? Also how did you connect the power lead, I assume into the glove box with the 12v connector?
Cheers for any info
Mike
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
Hi Mike
The TomTom Rider 550 Premium comes with an assortment of fittings including a ant theft attachment
I got the mount on ebay Here and modified t a little since that photo as it was vibrating too often and need its position altered a little, it is much improved now
My Honda dealer did the power supply, its only live with the ignition on, dont know where they connected, but the power socket is still free
I will try and get some updated photos
PS I have found what might be a better mount Here It mounts in a similar way
2019 Forza 300
Deksx
Year: 2018
Re: Newbie
Post by Deksx »
Thanks Forzy for the reply and links. Would also love to see any more pics. Its my main wish to have some sortd of sat nav. Ive been wracking my brain how yo mount something :-). Lol im so not technicsl
FORZY
Color: Black Forza
Re: Newbie
Post by FORZY »
This is what mine looks like atm
2019 Forza 300
