Clear flood mode
Mikes150pcx
- Color: Metallic grey
Clear flood mode
I am a bit curious if anyone or everyone knows about clear flood mode? Just like a car you can turn on the ignition and then twist full throttle then push start and the ecm will not open the injectors untill you back off on the throttle. So is this common knowledge? Just curious.
- DAB
Re: Clear flood mode
How would you push start a scooter?Mikes150pcx wrote:I am a bit curious if anyone or everyone knows about clear flood mode? Just like a car you can turn on the ignition and then twist full throttle then push start and the ecm will not open the injectors untill you back off on the throttle. So is this common knowledge? Just curious.
Other rides
Mikes150pcx
Your bike all ready has it!Jge64 wrote:Why would you need this feature?
Mikes150pcx
I don't know why you asked that?DAB wrote:How would you push start a scooter?Mikes150pcx wrote:I am a bit curious if anyone or everyone knows about clear flood mode? Just like a car you can turn on the ignition and then twist full throttle then push start and the ecm will not open the injectors untill you back off on the throttle. So is this common knowledge? Just curious.
It's in all the past owners manuals, page 33 of the older PCX150 pdf I keep a copy of (as I have a 125)
- untitled.jpg (42.48 KiB) Viewed 5012 times
- DAB
Misunderstood "push start" on the previous post. Took it to mean bump start.Mikes150pcx wrote:I don't know why you asked that?DAB wrote:How would you push start a scooter?Mikes150pcx wrote:I am a bit curious if anyone or everyone knows about clear flood mode? Just like a car you can turn on the ignition and then twist full throttle then push start and the ecm will not open the injectors untill you back off on the throttle. So is this common knowledge? Just curious.
Other rides
Mikes150pcx
I didn't know there was info on that in the manual! I guess it wasn't important!
Inoplanetyanin
- Color: WHITE
Yes, I had to use it while trying to start the PCX that's been sitting for two months.
