YSS fork spring
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
YSS fork spring
Post by alx123 »
So, I found this YSS front fork spring being sold by bikerbitz.
yss fork.jpg (3.84 KiB) Viewed 2870 times
Has anybody tried using this? What improvements on my front suspension (if any) will it do?
I know a YSS upgrade kit with PD valves and preload adjuster (photo below) is also being sold but buying just the spring is a lot cheaper. What difference will the PD valves and the adjuster make?
Cube
Office Minion
Office Minion
Year: 2018
Color: Dark Pearl Blue
Re: YSS fork spring
Post by Cube »
I don't have experience with that exact system, but I put a similar one on my old Ninja.. the preload allows you to adjust the sag settings, while the valves allow adjustment of the damping forces on the front end. Ever ridden in or seen a car with blown shocks? That bounciness is a lack of damping.
Here's an explanation:
https://www.rideapart.com/articles/2579 ... n-damping/
2018 Dark Pearl Blue PCX150
2014 Glowing Red Forza 300
Re: YSS fork spring
You could try the spring and go up a few weights in fork oil to help with the damping?
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Re: YSS fork spring
Post by alx123 »
you you wrote:You could try the spring and go up a few weights in fork oil to help with the damping?
This I will try youyou. Thank you
