2019 PCX 125 - air filter box
- Tommy
- Year: 2019 125cc
there's one screw in front that is so unreachable, other 5 to the back are not a problem.
any hints how to get there without taking whole sidepanel out(which would take some work I believe)
looking to remove 'snorkel' from inside of the air box ...
thnx
thnx
Yamaha fazer S2 600cc 110HP 2009 rip
Yamaha Xmax 400 35HP 2016 rip
Honda PCX125 2019 10HP
Re: 2019 PCX 125 - air filter box
Why?Tommy wrote:looking to remove 'snorkel' from inside of the air box ...
gn2 wrote:Why?Tommy wrote:looking to remove 'snorkel' from inside of the air box ...
+20bhp
- Tommy
- Year: 2019 125cc
Well, I've read here the sound gets better when rubber 'snorkel' is removed.
I know.it is placed there for at least 3 reasons
(From my experience with engines...)
1. Longer inlet reduces spitting back from the engine, because spitted particles get sucked back in before they escape the pipe
2. Better positioning of the air suction point in middle of the box/filter, better flow patter on filter(not sucking from one end/front, for example)
3. Less noise obviously than without 'snorkel'
But that aside,
Really, even for a simple filter replacement, how do you do it w/o taking the panels off?
Thanks
But that aside,
Thanks
- IMG_20190702_222545.png (2.51 MiB) Viewed 3865 times
If its like the 2010 model I had, you'll need to take the panel off.
Maybe you could pop the pillion peg down and cut an access hole behind it?
accyuklad
- Year: 2010
is it safe to remove snorkel because wouldn't it get more shit stuck to the air filter
Top quality thread.
accyuklad
- Year: 2010
as anyone tried removing snorkel and putting k&n filter
accyuklad
- Year: 2010
Ordered simota filter instead
K&N filter, Yesaccyuklad wrote:as anyone tried removing snorkel and putting k&n filter
accyuklad
- Year: 2010
just fitted simoto I think it called and removed snorkel idle sounds same as stock setup and if you rev it when riding sounds well good but soon as you don't rev hard it seems normal
