So, my day has gotten worse
I sent it to a shop, but they could only receive it, and couldn't tell me anything about it.
So..... how screwed am I?
How large is the piece that was broken off, is the threaded hole just stripped, or is part of it actually broken off? If it can be tapped & a larger plug / bolt can be secured to seal it, then you can leave it as is and simply do future oil changes by siphoning thru the fill tube like ‘youyou’ does.I stripped it, and broke a piece of the housing off of the oil bolt housing.
springer1 wrote:How large is the piece that was broken off, is the threaded hole just stripped, or is part of it actually broken off? If it can be tapped & a larger plug / bolt can be secured to seal it, then you can leave it as is and simply do future oil changes by siphoning thru the fill tube like ‘youyou’ does.I stripped it, and broke a piece of the housing off of the oil bolt housing.
Good to hear, I thought I was gonna have to buy a new engine!fish wrote:R crankcase is priced at @$75 if it cannot be repaired.
Friend of mine used a cheap torque wrench to snug the 2 exhaust nuts to the head - heard no 'click' so started stripping the studs out!
Stuff happens.....especially when we're a bit preoccupied.
About a quarter inch piece fell off. I literally turned it until it was easy to turnspringer1 wrote:How large is the piece that was broken off, is the threaded hole just stripped, or is part of it actually broken off? If it can be tapped & a larger plug / bolt can be secured to seal it, then you can leave it as is and simply do future oil changes by siphoning thru the fill tube like ‘youyou’ does.I stripped it, and broke a piece of the housing off of the oil bolt housing.
Thanks I'll update tomorrow morning when I talk to the mechanic. I'll mention these words I don't understand to them...crankcase, tapped and plugged, helicoil... lol i'll go with the longest term solution. I started literally thinking of all the good times I had after I sent it off to the shop and have been so bummed wondering if I'm gonna have to get a new engine. Y'all are definitely making me feel better lolyou you wrote:springer1 wrote:How large is the piece that was broken off, is the threaded hole just stripped, or is part of it actually broken off? If it can be tapped & a larger plug / bolt can be secured to seal it, then you can leave it as is and simply do future oil changes by siphoning thru the fill tube like ‘youyou’ does.I stripped it, and broke a piece of the housing off of the oil bolt housing.
Or the filter housing.
Any decent shop should be able to helicoil it.
We’ve all done something like this at some point. If you haven’t yet, you will.
Good luck
No pics, just sent it away. no confidence to do anything on my own anymore. Sheesh! I'm surprised I was able to install some YSS shocks on my own last summereasyrider wrote:Picture?? sounds fixable !
