Actually having a lot of fun rebuilding my CB250 (see top pic) so I've gone and bought a little "project" - a blue 1999 Honda CG125. Parts are far cheaper and more plentiful for these models as they made so many of them so I'll probably splash out on this one. Should keep me busy until the weather improves
Impressive photo . . . looks more like a laboratory with R & D going on.
When I get into unfamiliar territory I take pictures every step on the way into the project so if I get disoriented on reassembly I have a step by step photo trail to refer to. It helps to avoid confusion and wasted time.
The Service Manuals are what they are so by using a "trail marker" method and the manual I find it reduces the risk of ending up with extra parts/pieces when everything is put back together.
I'm kind of a wimp when it comes to working on top ends or transmissions so I figure as long as I keep the valves in spec, change the engine/final drive oil and keep things lubed, clean/replace filters, make any and all scheduled adjustments, replace fork oil, chains, belts, hoses, bulbs, cables, or brake pads as needed, check areas like the steering head bearing for tightness, etc. . . it goes a long way to keeping the machines going a long way and out of the shop.
I try to keep a good supply of paper towels and Windex on standby when the camera is needed. I find using nitrile or latex gloves helps keep the hands clean . . . but not necessarily dry. That said if the job is not too obnoxious I prefer not to use them.
Good luck with your retro rebuild!
