Recalibrate Forza Speedo (2015 model).
erisaman
Year: 2015/Forza 300
Post by erisaman »
Hi, I've fitted a smaller wheel to the rear of my 2015 Forza NSS300 (long story - will reveal all shortly) and the speedo appears to be over-reading by up to 20%. I'm sure I've read a post at some time advising the means to re-calibrate the speedo - but a 'Search' has not found the post.
Thanks for your patience.
If you don't stand for something - you'll fall for anything.
Re: Recalibrate Forza Speedo (2015 model).
Make sure you advise your insurer of the modification.
erisaman
Post by erisaman »
Any 'modification' to be reported to the insurer is rather more than merely changing the rear wheel size :). You ain't seen nothing yet - although I did ask (and you replied - thank you) for advice via a PM some months ago. 'Much water under the bridge' - or rather - 'much rubber on the road' since then - and you will hate it .... but I luv it. Just get these final wrangles out of the way and I'll be an 'appy bunny.
But thank you again.
E. Foster Salsbury
Year: 2015 NSS300A
Post by E. Foster Salsbury »
I've heard there is this thing called a "speedo healer". I've never used one and I don't know if it'll work on your Forza.
https://www.google.com/search?client=fi ... edo+healer
Salsbury
