There's nothing to deal with, you use petrol, it works.Fugu wrote:Deal with it.
Have you ever tried diesel in a PCX?
I have.
Now that is something to deal with!
Fugu wrote:I've heard that story a thousand times now.you you wrote:Fugu wrote:That explains a lot :-)
Thanks for the answers! There is actually no difference at all then on the Octane then.
No, there's a difference between octanes but it doesn't make any real difference to the PCXs running.
bla bla bla. I see different people, saying different things about Normal or Premium Gas.
Personally I only use the Premium gas, because I can feel the difference. Deal with it.
Nice one Skywalker.Fugu wrote:you you wrote:Fugu wrote:Personally I only use the Premium gas, because I can feel the difference.
Nosubstance wrote:A article I read says when we use higher octane fuel in a engine that requires 86 octane we are wasting our money. Could be up for debate. The HM (Honda Manual) states 86 or higher can be used. I recently fueled up with 86 octane and it doesn't accelerate as fast as when I fuel up with 91 octane. Currently avg about 86-96 MPG on 86 octane. When I use 91 octane I get avg 100.1-103.6 MPG. MPG does vary with the following variables such as Wind, Hills (steep grades), and weight. Been wanting to test racing fuel that is 100+ octane rating. In my case the difference in MPG has little difference between the fuel grades. I may try mid grade which is 89 and blend of 86 and 91 respectively.
Not correct. Higher octane is harder to IGNITE. That’s why it’s needed in hi compression engines, octane does not relate to energy produced, only to how much heat & compression will ignite it without spark.Using a higher octane of fuel than needed will not hurt your engine but it will cost more and give LESS performance. The higher the octane the slower the burn of the fuel. The slower the burn the less energy, and less energy means less power.
Top tier fuels are not necrssarily any better than other fuels.Its a gimmick !All fuels have to meet Federal guidelines and contain govt required detergent additives.Those who choose to pay a lab to certify that they meet the standards are then granted the top tier designation.If you pay you play.Just like Mobil One refused to pay GM to license thier DEXOS logo.Mobil One beats their requirements and did not feel a need to pay GM their ridiculous licensing fees.Same with top tier gasoline.Its all BS.All gasoline is raw,only additive detergent packages make them slightly different.fish wrote:If in the USA, use only Top Tier labeled fuel. It costs no more, and has good stuff for your engine. Check web site to see the stations. In Ohio, Speedway is not a Top Tier fuel.....although it is hugely frequented in my area. Down the street is Valero and BP....both are T.T.
Same $.
Did that once.Mel46 wrote:don't put Diesel in your scooter unless you don't want it to run.
What's the compression ratio on the PCX engine?easyrider wrote:Higher octane is only necessary in high compression engines mostly found in high performance motors .Because of high compression ratio anti knock additives are required hence high octane.They have higher anti knock additives not more power.The Honda scooter engines are not high performance requiring anti knock fuels ( high octane).
