Your thoughts on these color combo's
C-Note
Post by C-Note »
Any thoughts on any of these color combinations. I am thinking about doing one of them just for something a little different. Personally, I like the first one the best. Panels are cheap!
Teamtd11
Re: Your thoughts on these color combo's
Post by Teamtd11 »
I like 3 and 5. I think white and red would be an amazing combo too!
Urbanian
Post by Urbanian »
Teamtd11 wrote:I think white and red would be an amazing combo too!
I think they sell a red and white PCX in Canada (national colors and all...)
figurehead71
Post by figurehead71 »
Yep, this is it, although personally I think an inverse colour job would look nicer.
figurehead71
My own thoughts to the colour combos, I am not personally keen on mixing up the front panels colouring with the trim colouring above lights/below windshield.
I kind of like number 2 and 4..with 4 being preference personally.
EddieC
Post by EddieC »
last one... HANDS DOWN! :lol:
Taz
Post by Taz »
i like the 3rd.
Urbanian
Post by Urbanian »
figurehead71 wrote: personally I think an inverse colour job would look nicer.
AGREED!
I do like the way the red comes stock. I wouldn't change it.
However, if white had been available in the 150, I would have bought it first.
That said, I think this is probably one of my favorites:
Theboybilly
Post by Theboybilly »
3, and especially 5 - very nice
Bill
Image[/URL
Hmm....I'm not really a fan of the choices after #1, sorry. Are those grey panels? How about black instead? Although I think white might (?) look better in the mix with red? Just my 2cents. Dunno. Spray painting is another idea? Yikes o_O There are some very good canned plastic sprays on the shelves, i.e.: Krylon Fushion, RustOleum. Best I sprayed was an exterior dryer exhaust cover and an exterior light fixture. Pretty cool stuff. Would I take on some scoot panels? With a friend perhaps (I'd need some confidence support :oops:)
Did You make a choice yet? :D
philvb
Post by philvb »
C-Note wrote:Any thoughts on any of these color combinations. I am thinking about doing one of them just for something a little different. Personally, I like the first one the best. Panels are cheap!
I like the first one.
Wow, the first one looks sweet! Cool idea. :D
oyessum
Year: 2021
Post by oyessum »
I also like the first one best. Then again, I'm partial to the stock arrangement for white and red. Black is just all black. :(
C-Note
Post by C-Note »
WhiteNoise wrote:Hmm....I'm not really a fan of the choices after #1, sorry. Are those grey panels? How about black instead? Although I think white might (?) look better in the mix with red? Just my 2cents. Dunno. Spray painting is another idea? Yikes o_O There are some very good canned plastic sprays on the shelves, i.e.: Krylon Fushion, RustOleum. Best I sprayed was an exterior dryer exhaust cover and an exterior light fixture. Pretty cool stuff. Would I take on some scoot panels? With a friend perhaps (I'd need some confidence support :oops:)
The panels are actually supposed to be Black, I used Photoshop to mock these up using a color replacement tool. Anyway, yes they are black.
Choice #1 is my favorite too. Painting is a good idea, and I did think of that option too. But these two lower panels are less than $10 ea., and easy to replace. So it made sense to me to simply swap them out.
Alrighty C-Note good choice :) So the deed is done then? I doodle around with coloring using paint (I know it's sloppy and a pita, but I doodle anyway). I used a black pcx for this one, then I colored away :geek:
2013 Honda PCX 150 color me 1.jpg (23.72 KiB) Viewed 8077 times
C-Note
Post by C-Note »
WhiteNoise wrote:Alrighty C-Note good choice :) So the deed is done then? I doodle around with coloring using paint (I know it's sloppy and a pita, but I doodle anyway). I used a black pcx for this one, then I colored away :geek:
I have not done anything just yet. Probably will wait until spring now since the bike is stored now.
That's the idea. In Photoshop you can select/define an area and use the Brush Tool to 'replace' the color in the selected area. So when I do it, I select panel outlines. The replacement tool keeps the lighting the same so it looks pretty good.
Black Bandit
Post by Black Bandit »
I love the 1st photo! It's the best as you said.
jasontheparamedic
Post by jasontheparamedic »
I like #1 the most.
Taz
Post by Taz »
If I need to start replacing panels on my white 125 I may get reds or blacks as a combo mix with any remaining whites. Red wasnt a choice here until the 150 came out. Scooters should be colorful, not drab all black or grey!
Black Bandit
Taz wrote:If I need to start replacing panels on my white 125 I may get reds or blacks as a combo mix with any remaining whites. Red wasnt a choice here until the 150 came out. Scooters should be colorful, not drab all black or grey!
I'm going for an all black look but with the side and fuel cover consoles "shiny" black instead of the dull black stock Honda look. Should look sweet I think.
