Awesome 2 stroke
springer1
Year: 2018
Awesome 2 stroke
Post by springer1 »
Jump to 12:20 on the attached video and checkout the ride on this Vespa with a custom engine. If nothing else, you can see how the clutch and gearshift are integrated in the the left handlebar / grip / lever. I rode a 150cc Vespa (actually it was a "Stella") for 4 years and it was awesome fun, but 2 stroke Stellas have a tendency of seizing at speed once they get mileage on them - so I sold it and thus have the PCX.
https://www.youtube.com/watch?v=EmlgEP-ihls
PCX150Rider
Re: Awesome 2 stroke
Post by PCX150Rider »
Cool video. 8)
The oncoming white car near the end looked "over the line". :roll:
I had hoped for a Stella a couple of years ago but after reading about the problems I decided against it. The newer version they introduced had electrical problems and an ECU recall right at the get-go. Sadly the manufacturer, LML, has decided not to produce them anymore so the last vestige of the old Vespa P200 type scooters, as the Stella exemplified, is no longer available. :(
That being said the PCX works for me. . .. It's not "retro" but it is certainly reliable, economical, performs well, and parts or dealerships/service is widely available. ;)
How many quarts of oil per mile??
easyrider
Color: blk
Post by easyrider »
Reminds me of those clown cars from yesteryear.. Not for me to drive , but definitely something for the shelf.
springer1
Year: 2018
Post by springer1 »
Mel46 wrote:How many quarts of oil per mile??
Not much. The spec was a 2% mix, provided by the bike's auto-lube (no manual mixing required). But I thought that was a bit short so I also mixed 1% to to the fuel. But not before I first added a CHT (Cylinder Head Temperature) gauge to get baseline stock engine head temps in real time in various ride conditions ...... I wanted the baselines to compare engine temps with after I made oil mix and fuel jetting changes.
Adding oil to the fuel actually leans out the fuel mix because the added oil displaces fuel - so you can wind up with a well lubricated piston seized from excess heat from a lean mix.
So I richened both the high end and mid range jets to compensate for both the added oil and to also make sure the stock engine wasn't a bit lean in order for them to meet EPA requirements. I've been around a while, and I never heard of ANY 2 stroke guys mixing just 2% oil. Many people just let the auto-lube do the 2%, but I didn't feel comfortable with it.
Anyways, I never had any problems - and the new 2T synthetics burn so clean that 3% resulted in zero carbon or ash buildup in the combustion chamber that I could find, even with the richened fuel jets.
Mister Paul
Post by Mister Paul »
Nowt wrong with a proper Vespa. Had a PX125 years ago. They're holding their value over here now, so I'll have another one in the not too distant.
