Hot wired Stolen PCX125 2014 , 4-pin connector missing
Re: Hot wired Stolen PCX125 2014 , 4-pin connector missing
about...."sitting tight for an update"
No worries, I'm hanging in and hanging on :D
St.Clair
Color: Black & Red
Post by St.Clair »
How didi you get on with this Part by the way. Did it show up and fit. I am also trying to locate this part for a project I am working on. Can you remember the UK supplier.
I do not think there is any thrill that can go through the human heart like that felt by the inventor as he sees some creation of the brain unfolding to success... such emotions make a man forget food, sleep, friends, love, everything.
Nikola Tesla
flyingzonker
Post by flyingzonker »
I wish you luck.
Probably the best luck you could have is to get out of London. Happy me to live in a town that is big enough to be interesting but too small to support a lot of sophisticated felons. The sharp cats and big timers all head for Megalopolis.
Patkin3484
Color: Gloss White
Post by Patkin3484 »
I realise this is an old post but it may help others. in the absence of a plug, you can dremel or cut the plastic shroud from around the 4 pins. then you can simply use 4 insulated male connectors pushed over each pin. you could even solder the wires to the pins and use an aftermarket 4 pin plug and socket instead.
raf186
Post by raf186 »
Hi Guys
Any update regarding this project? My PCX was hotwired and I am looking for some help please
