Hello all, My name is Erika and I am totally new to this site so I appreciate all of your honest and educated replies.
I just purchased a 2017 Honda PCX and am loving riding it.
Have had the scooter for about a month now and I am noticing the left hand brake lever is so much LESS sensitive than my right hand brake lever.
Meaning I have to pull on my left hand lever much harder to even get the brakes to engage.
Is this normal? Do I just need to take it back to the dealership and have them adjust my brake lever?
Thank you in advance.
Left Hand Brake Lever
Thichtake82
- Color: Blue
- Year: 26 adv 160
Re: Left Hand Brake Lever
Normal, the left brake engages the front/rear combined braking system, the right just the front.
You may need to adjust the back brake some. There is an adjustment nut on the left side by the back tire. It is below everything else when you look at the rear tire on the left side. Turn the nut and try the brake lever to see if you are tightening or loosening it. After you get it so that the lever feels tighter then make sure that the rear brake is not making contact with the drum when not engaged by turning the rear wheel. You should be able to feel when it is doing so. Then you would need to back it off a little bit.
The left lever operates a completely different type of braking system, on the rear wheel it is a bowden cable operated brake like on a regular bicycle.
The left lever also operates one third of the front brake.
The combination of the two means you need quite a lot of input force.
The right lever is a hydraulic brake, much more powerful, much less input force required.
The "feel" of each will never match, you just have to get used to them over time.
The more you ride the more you won't notice
