Hello.
I have a real problem with my vision 110. It refused to start on Monday morning :-(
I can hear the starter motor turn over but it did not sound like the the Bendix drive was catching. In the evening I leaned the bike over as far as I could to the left and got it start eventually.
The next day it would not start again.
Today the starter motor sounded like it was slowly getting weaker as it turned over (if that makes any sense) and then sized up I think. I then opened the belt case, took of the cover for the bendix/pinion drive and could see that the teeth of the bendix were just behind where they would meet up with the teeth of the variator.
When I try to start the bike the bendix move forward onto the variator and then stops. (i have taken photo's but cannot upload).
Please help. Does the bendix need changing, the starter motor or both.
Thanks
Honda vision 110 not starting
dick the den
Re: Honda vision 110 not starting
I Have had my Honda vision 110i,for 31 months,and have done approx. 12500 miles,not every time it sounds like it dosent engage..???????????
And then stats up with a cluck..??????????? But it then fires up not heard another one start,so cannot compare it.
If you can use another battery,try that
When it gets a bit [lots] warmer will post up a meet-up at High beech in Essex,on a other forum I belong too.And on here too.
- lillypinkjenny
If you are in London, give Dave Wilkins Motorcycles a shout.
Dave is at 59 Jasmine Grove, London SE20 8JY.
Phone 020 8249 7940.
Real old skool Honda guru.
I have a USA Honda Elite 110 which I think is the same as your bike. My bike did the same thing and it was a weak battery.
dick the den
Agreed its round the back,to the rightlillypinkjenny wrote:If you are in London, give Dave Wilkins Motorcycles a shout.
