Spare Key for PCX>
- pcx888
- Color: pearl white
Spare Key for PCX>
Does anyone know where to get a spare key. Ebay want to charge 40.00 Might as well buy ignition set with new keys any suggestions. I tried getting on at a honda dealer and says not available.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Re: Spare Key for PCX>
You should be able to make a standard replacement key for it. You won't be able to lock and unlock the key cover on the bike, but at least you would have a spare.
When I needed a spare for my Burgman 400 I ordered a blank on eBay and had a locksmith cut it for me.
Get Marc to ask for you?pcx888 wrote:Does anyone know where to get a spare key. Ebay want to charge 40.00 Might as well buy ignition set with new keys any suggestions. I tried getting on at a honda dealer and says not available.
- pcx888
Who is Marc.you you wrote:Get Marc to ask for you?pcx888 wrote:Does anyone know where to get a spare key. Ebay want to charge 40.00 Might as well buy ignition set with new keys any suggestions. I tried getting on at a honda dealer and says not available.
2011 White PCX
- Color: red
The problem with that is that you have to strip the tupperware to install it. I bought my PCX used with only one key. Like you, I found that the blanks are all but unobtainable. I ended up getting a blank from the UK via Ebay and then having the locksmith cut it. I think it came out to about $35 all totalled.Ebay want to charge 40.00 Might as well buy ignition set with new keys
But Murphy's Law says that when you need to use your spare key, someone will have closed the lock cover!You won't be able to lock and unlock the key cover on the bike, but at least you would have a spare.
Marquezpcx888 wrote:Who is Marc.you you wrote:Get Marc to ask for you?pcx888 wrote:Does anyone know where to get a spare key. Ebay want to charge 40.00 Might as well buy ignition set with new keys any suggestions. I tried getting on at a honda dealer and says not available.
- pcx888
I get it now., Thats was a picture I took when I went to Honda Factory Museum located in Torrance California. But I work for Honda Auto Division. Cannot get parts for motocycle division.
2011 White PCX
hrtEG2ExQ4uSvMJI9YgtWzRRKuqIPiHU2FURxerDOFazW9LMaAk1eEALw_wcB
Could this one work?
- pcx888
ur link doesnt work.Mel46 wrote:hrtEG2ExQ4uSvMJI9YgtWzRRKuqIPiHU2FURxerDOFazW9LMaAk1eEALw_wcB
2011 White PCX
Beware of Chinese steel key blanks on the net. Your local locksmith won't put a steel key blank in his machine... must be brass. They can look silver on the outside but must be solid brass inside.
Yep, local locksmith verbally attacked me after I handed him my Chinese/ebay Burgman key blanks. "Trying to ruin my cutter!!?"homie wrote:Beware of Chinese steel key blanks on the net. Your local locksmith won't put a steel key blank in his machine... must be brass. They can look silver on the outside but must be solid brass inside.
No clue what was going on, so took blanks to local hardware store where the kid cut them for $2.
Crap....who knew?
https://m.bonanza.com/listings/1-x-igni ... 3AQAvD_BwE
See if this link works. The price and shipping are ridiculous but it may give you an idea about searching on the web.
Here is one I came across that made no sense to me but may make sense to others
https://www.ebay.com/itm/Blank-key-for- ... f7&vxp=mtr
- Color: red
I had gotten one of these:
https://www.ebay.com/sch/sis.html?_item ... 4100.l9146
The local locksmith charged me 6 bucks to cut the key, so it's going to end up costing $20-$30 in any case. The fun part was the trial-and-error with the little magnets to figure out which of the four holes to leave blank to activate the ignition flap.
If you have one orig. key....set your new magnets on the ones on your orig. key...they will fairly hop into the correct position. ..now move them to new key without flipping them...use same holes.(Suzuki Bulgarian keys work same way)tjupille wrote:I had gotten one of these:
Baddabing.
not a typo
- pcx888
Thank you for the info.
2011 White PCX
the security knob is my problem i have weak wrists and grip carpel tunnel the knob on my key is getting worn in just 2 months. holding it in place and turning the key is a problem for me
