Oxford hot grips and Tucano muffs.
seanyp83
- Color: blue honda visi
Hello.
Wanted to know if it were possible to fit Oxford hot grips and Tucano muffs?? Will the operation of the throttle be hindered by having handlerbar muffs installed?
I have a Honda vision 110 but would like to know if anyone has successfully done this on any scooter.
Thanks.
Sean
Thanks.
Sean
dick the den
Re: Oxford hot grips and Tucano muffs.
I Have a Honda vision 110,scoot,not oxford but dr.some thing heated grips ,I don't no..????????? But give them a try,whats your view of the vision..?????????????
I Cannot prise it enough,it does what it does no more.
I have seen several discussions on this forum about the hand muffs. Here is one of them.
http://hondapcx.org/viewtopic.php?f=2&t ... ffs#p99057
dick the den wrote:I Have a Honda vision 110,scoot,not oxford but dr.some thing heated grips ,I don't no..????????? But give them a try,whats your view of the vision..?????????????
If you keep on doing this I can’t take the piss out of the North Americans for being stupid and/or semi literate.
Try harder.
Unless you are being ironic. In that case well done, it’s a work of art.
seanyp83
Thank you.
I think the vision is a great bike.
I've hit a massive problem trying to fit the heated grips. when trying to remove the throttle side bar end I have stripped the screw head. :-s I tred to drill it out with a metal drill bit and damaged my drill bit to the process. Really need help with this. can I get a metal hacksaw and try to saw hrough the screw or would i be better off using a screw extractor tool?
Thanks again
Thanks again
Rode a vision on my CBT, far too small for a 6ft man whereas the PCX feels so much better.
I damaged a screw bit trying to get the bar end bolts out (three of us holding the bike and putting pressure on the bit and trying to turn it). Stripped one of the screw head just like you did. Bought a special drill bit that proved to be useless.
In the end I used a combination of 3 normal metal bits ranging from small to 6mm and a normal action electric drill - worked like a charm. Took a few minutes each side, and the bit/screw got so hot not only did the loctite melt and loosen but sparks were coming off the screw head as it was drilled into! Fitted allen key bolts as replacements.
To get the Ebay universal hamd guards fitted, keeping the original bar ends, I needed slightly longer bolts than came with the bike - 60's rather than 45's from memory.
iceman said, "fitted allen key bolts as replacements."....."keeping the original bar ends, I needed slightly longer bolts than came with the bike - 60's rather the 45's from memory."
A good bit of advice right there!
iceman for our viewers (that includes me), would you please show us an example of the Longer replacement bolts used? A pic off the www would be fine.
In reference to loosening tight finicky bolts, a spritz of this on those bolts the night before or a few hours before "the attack"
helps. I used it on my tight handlebar bolts. Easy peasy removal afterwards.
PRIOR TO SPRAYING: wrap the grips with rags and throw a towel over surrounding area (in case of overspray). Good Luck!
- image.jpeg (36.14 KiB) Viewed 6713 times
Not able to take a piccy right now. I only needed longer bolts as the universal hand guards and small plastic bits sat proud of the original bar ends, adding some depth. They came with replacement plastic bar ends and inners but not suitable for the PCX and the originals are best (heavy for a reason).WhiteNoise wrote:iceman said, "fitted allen key bolts as replacements."....."keeping the original bar ends, I needed slightly longer bolts than came with the bike - 60's rather the 45's from memory."
A good bit of advice right there!![]()
In reference to loosening tight finicky bolts, a spritz of this on those bolts the night before or a few hours before "the attack"helps. I used it on my tight handlebar bolts. Easy peasy removal afterwards.
https://www.ebay.co.uk/itm/2x-Universal ... 0507.m3226
- lillypinkjenny
Weirdly, I can read that and know exactly what dtd means to say ... I think ... well I hope, anyway.you you wrote:dick the den wrote:I Have a Honda vision 110,scoot,not oxford but dr.some thing heated grips ,I don't no..????????? But give them a try,whats your view of the vision..?????????????
Try harder.
seanyp83
Thanks Iceman.
What type of metal drill bit did you use? will these work?
https://www.ebay.co.uk/itm/Heller-13-Pi ... XQVT9TBokp
or should I get something best with a cobalt tip? Also did you use a cordless drill or one that you plug in please (was thinking whether a high powered drill is needed).
Thanks again.
Thanks again.
WN,
What is the name of that spray? I tried to zoom in on the picture but I don't see a full name.
- Limey
- Year: 16 Forza/16 PCX
- Color: Red/Maroon
Mel - it's 'PB Penetrating Catalyst'.Mel46 wrote:WN,
You can get it on Amazon:
https://www.amazon.com/Blaster-16-PB-Pe ... rating+oil
- DAB
I have found that a set of left-hand drill bits are a useful addition to the tool kit. Often the heat generated while drilling will free the stuck bolt. Much better on smaller size bolts.
Other rides
montliz44
- Year: 2013,2014
- Color: red+redder
To SeanyP's OP, I have a set of Tucano muffs on my Forza and they work quite well. I did have to cut out a little bigger thumb hole in the left one to get better access to the turn signals switch, but other than that they're well-made and easy to live with.
Johnny
Johnny
I bought a special cobalt drill, next to useless but that may have been due to the shape of the drill bit head. I then used very old bits I have had around for years (must be 20+ years old) and they worked like a charm. The bolt is not that hard as it can be stripped easily, indeed the loctite is tougher or so it seems as that does not give. Best get a few 2mm, 4mm and 6mm metal bits and use them - cheap ones should be ok.seanyp83 wrote:Thanks Iceman.
What type of metal drill bit did you use? will these work? https://www.ebay.co.uk/itm/Heller-13-Pi ... XQVT9TBokp or should I get something best with a cobalt tip? Also did you use a cordless drill or one that you plug in please (was thinking whether a high powered drill is needed). Thanks again.
seanyp83
Thanks Iceman and thanks everyone for your replies :-)
Will let you know how I get on.
dick the den
iceman wrote:Rode a vision on my CBT, far too small for a 6ft man whereas the PCX feels so much better.
I am the other way round,the pcx is far to small in size for me,6"3",but the vision is better.
- PCX150Rider
As a cheap alternative to the more expensive muffs these are also available. Sold under the name Kwik-Tek or Scooter Logic. Other accessories also available.
Link for the muffs.
https://www.amazon.com/Kwik-ScootR-Logi ... oter+logic
Link for the bags.
https://www.amazon.com/ScootR-Logic-SLS ... oter+logic
Reviews are generally good. I've had them on my wish list for some time. Still thinking.
Link for the muffs.
Link for the bags.
The universal handguards off ebay (£10 or thereabouts) stop some of the wind but need an extra few inches on top and underneath to stop more wind (wondering how best to extend of fit something over them), but also just spotted these off the link PCX150Rider gave:
https://www.amazon.com/dp/B00S1NDC9Y/re ... B001KOF05A
Wonder if they would fit or could be made to fit the PCX? (also only for sale in the US, but looking to see if anyone knows of someone using these?)
Robbie
- Color: Grey
Seany, I have oxford heated grips and urban tucano bar muffs fitted to my PCX. I still use autumn gloves and my hands are fine in sub zero temps. Admittedly my commute is only 7 miles but the grips get too hot to hold unless you wear quite thick gloves, so I have to turn them down!
All in, grips and muffs make a huge difference to your hands. I locked the front brake up twice today (on grit, not ice) and was able to feel the lock and release it in enough time to stay on.
