Leds For 2011 PCX
pcx888
Color: pearl white
Leds For 2011 PCX
Post by pcx888 »
Has anyone been able to get 2011 Leds. The stock bulbs suck so bad. I want to get white color if possible.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Gil
Re: Leds For 2011 PCX
Post by Gil »
Which bulbs do you want to convert to LED?
Gil
pcx888
Color: pearl white
Post by pcx888 »
the main headlamps
2011 White PCX
Gil
Post by Gil »
I retrofitted the LED headlight bulbs onto my scoot, but it wasn't a plug and play. I used my 3D printer to print a OEM type lock on mechanism to use with the LED bulbs. The LED bulbs that I used mimicked the H4 filament layout, making my high beam useless. I still haven't found a plug and play LED headlight bulb. I working on a better solution, ei looking for better designed LED bulbs. I recommend LED bulbs with Philips lumileds SMD LEDs. They provide the smallest bright LED chip that can more accurately mimic the OEM bulbs filament position. I'll add some pics, in an hour or so.
Gil
Gil
Post by Gil »
The led lights that i'm using have four led chips, per side of each LED "bulb", for the Low beam and another set for the High beam. Because of it the Headlights are too bright now. I'm looking for LED headlight "bulbs" that have 3 Philips Lumileds per side of the LED "bulb". The led lights i'm using aren't an official Philips product and might not even have authentic Philips LED chips. On official Philips H4 LED lights, they use 3 led chips per side for Low beam and a separate set for high beam.
Here is an example of the Philips H4 LED lights.
https://www.hidconcept.com/collections/ ... RrEALw_wcB
Here is a picture of the final product.
Gil
Gil
Post by Gil »
Here is a good review on the Philips H4 led retrofit. It shows how their LEDs work as good as halogen and why I'm looking to find the perfect chinese LED lights.
http://www.xenondepot.com/Philips-12953 ... w-s/62.htm
Gil
pcx888
Color: pearl white
Post by pcx888 »
can you make me a 3d printer locking clip.
2011 White PCX
Gil
Post by Gil »
Definitely, just cover shipping. I would need to know the diameter of the LED retrofit.
Ill add the 3D model to my public thingiverse account.
Gil
Gil
Post by Gil »
I added the locking clip to thingiverse.com. It's for an LED bulb with an outside diameter of 18 mm.
https://www.thingiverse.com/thing:2707796
Gil
chainsaw
Year: 2013 150esp
Color: white/carbon
Post by chainsaw »
i've been using the SYGNHOUSE led ribbbons for a couple of years now and they work beautifully. They are not the cheapest solution but are very good quality.
https://www.bolt.co.jp/news/news_led_ribbon.asp
Gil
Post by Gil »
Neat, does it have Hi/Lo Beam?
How much did you pay for it?
Gil
pcx888
Color: pearl white
Post by pcx888 »
Those ribbon leds are no longer made. So I gotta find a better solution.
2011 White PCX
chainsaw
Year: 2013 150esp
Color: white/carbon
Post by chainsaw »
yeah they do have hi/lo beam, bummer that they aren't available anymore.
chainsaw
Year: 2013 150esp
Color: white/carbon
Post by chainsaw »
the cost was around 320AUD so very expensive, but they are exceptional quality and nearly plug n play. I have replaced all the globes on my scoot with LEDs and these were the best quality by a mile.
Gil
Post by Gil »
Thanks for the info chainsaw.
Gil
pcx888
Color: pearl white
Post by pcx888 »
So weird that they dont make the bulb as a led no more. I think it has to do with the socket that has to be turned on be placed on. I found a ph11 bulb that has same plug. But wattage output is at 55 watts.
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
I ended up making my own.
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
I ended up making my own. There as brights as hell.
2011 White PCX
pcx888
Color: pearl white
Post by pcx888 »
look at my last post did my led headlights.
Gil[/quote]
2011 White PCX
