Split tire
Split tire
I've had my PCX150 for 2 months and 3,300 miles later I discover my rear tire has a large split. There's nothing I can remember that would have cause this. I need opinions, defective tire or no? Keep in mind I live in south west Florida, road conditions r much nicer than in areas that have to deal with frost, so there's zero chance it's because of road conditions.
Re: Split tire
I tried to edit my original post and add a pic but wasn't able to. I shouldn't say there's zero chance. There are reflectors in/on the road here that I've run over a couple times, would that cause this to split a tire?
Re: Split tire
good opportunity to switch to a better tire like a michelin city grip or pirelli diablo!
Re: Split tire
Err no, it is highly likely to be caused by something you have ridden over, or even vandalism.scisor34 wrote:Ithere's zero chance it's because of road conditions.
As said previously just change it for a Michelin or Pirelli.
Re: Split tire
for the sake of the cost,change it, not worth the risk of something happening if the tyre gives up
Re: Split tire
+1 to this comment, it really isn't worth the risk.trigg123 wrote:for the sake of the cost,change it, not worth the risk of something happening if the tyre gives up
Re: Split tire
I don't think he is considering reusing it but rather asking how it happened?JGC wrote:+1 to this comment, it really isn't worth the risk.trigg123 wrote:for the sake of the cost,change it, not worth the risk of something happening if the tyre gives up
Re: Split tire
Fair comment. It can be almost impossble to say what caused the split, unless you are aware of hitting something. A tyre centre might be able to say whether the tyre is defective or whether something else caused it.qed wrote:I don't think he is considering reusing it but rather asking how it happened?JGC wrote:+1 to this comment, it really isn't worth the risk.trigg123 wrote:for the sake of the cost,change it, not worth the risk of something happening if the tyre gives up
Re: Split tire
Once I discovered it, I never considered not replacing it. Not that this is related, but I thought I had read somewhere that the release of the PCX150 was delayed originally because of a tire issue, anyone else heard this? I ordered a City Grip that should be in Tuesday.
- HawaiiJ
Re: Split tire
The first 7,500 PCX150s delivered in Thailand had a tire recall issued due to a manufacturing defect discovered shortly after the PCX150 release in March 2012. The issue was with how the layers of the tires were manufactured, cured or vulcanized (not sure of the correct term). The possible result was separation of layers and the potential for vibration or tire failure at higher speeds. I believe the problem was identified and resolved prior to exporting any PCX150s out of Thailand. My original tires were replaced with about 2700K and showed not problems.
Re: Split tire
You probably ran over something. I've seen tires split after 10+ years from dry rot, but never as quickly as yours have split.
Is the split across the treads or parallel?
Post up a picture, just add it in a new post...
Re: Split tire
I had a girlfriend split
Daddio
Daddio
Re: Split tire
I am reminded of a joke involving masking tape and hamsters.
Re: Split tire
gn2 wrote:I am reminded of a joke involving masking tape and hamsters.
I wish. It wouldn't even have anyone's eye out.
Re: Split tire
Maddiedog, I've tried posting a pic, but haven't been able to, could you help me out? thanks.
- haildamage
Re: Split tire
you probably just need to upload it to a photo hosting site like photobucket.com first. then paste the IMG code into the message box.scisor34 wrote:Maddiedog, I've tried posting a pic, but haven't been able to, could you help me out? thanks.
Re: Split tire
scisor34 -- click Post Reply below. At the bottom of the page that comes up, below "If you wish to attach one or more files enter the details below," there is a box that says Browse. Click that box, select the file from your computer, and then click the Add the File button. When you reply, it will show up at the bottom of your post.
If you want the file inline, select the file from the dropdown that appears just below the text input area for the post, and click the Place Inline button.
