honda pcx power-full full led lo/hi
- power-full
- Year: 2010
- Color: preta
Here are the photos of the exchange of my lights, they were 36w / 36w x 8000lms / 8000lms x 6500k leds (each led lamp)
here is the video link
[youtube]https://youtu.be/9IwIfcTAcNc[/youtube]
- upload_-1.jpg (516.31 KiB) Viewed 5014 times
- upload_-1 (22).jpg (411.54 KiB) Viewed 5014 times
- upload_-1 (7).jpg (486.96 KiB) Viewed 5014 times
- upload_-1 (6).jpg (471.12 KiB) Viewed 5014 times
- upload_-1 (5).jpg (479.38 KiB) Viewed 5014 times
- upload_-1 (4).jpg (410.88 KiB) Viewed 5014 times
- origem vs led
- upload_-1 (3).jpg (276.84 KiB) Viewed 5014 times
- led
- upload_-1 (2).jpg (476.7 KiB) Viewed 5014 times
- origem 35/35w 12v
- upload_-1 (1).jpg (219.74 KiB) Viewed 5014 times
- IMG_20170926_074412.jpg (224.39 KiB) Viewed 5014 times
- power-full
- Year: 2010
- Color: preta
Re: honda pcx power-full full led lo/hi
Did you have to split the light assembly to do the upgrade? I am considering working on mine over the winter. Changing the main bulbs shouldn't be difficult (I have some HS5 bulbs I want to install there), but the top and bottom light sockets are empty. Those are the ones I am considering doing something with.
- power-full
- Year: 2010
- Color: preta
I did not do anything too much. only I applied the lamps "the ones I bought are h4) was to arrive and to assemble.
this as of origin is only in LEDs and has lots of light
- Slowinitdown
Nice upgrade. Makes the old bulb look like candlelight
- power-full
- Year: 2010
- Color: preta
- power-full
- Year: 2010
- Color: preta
hi hello .. this week I want to see if I'm the one next to mount my yuminashi kit on my pcx.
is the complete 164cc kit, I'll also fit the final gear kit, the AFR (injection driver). as well as the gasoline injector of greater debit "tuning of model honda cbr 150cc" and inertia power booster .
I will try to insert here the references of the material, my pcx is a 125cc 2010 model of the jf28 engine.
YUMINASHI FUEL-ADJUST CONTROLLER (5-PIN TO 5-PIN),38772-KWN-000A
44T FINAL GEAR SPROCKET SET, COMPLETE WITH SHAFT (PCX125 / SH125i)
23430-KWN-440
INERTIA POWER BOOSTER SET 15431-KWN-000
164CC LIGHT BORE FLAT DECK CYLINDER KIT (PCX125 V1) 12103-KWN-600XA
Honda Keihin injector assy (Tuning CBR 125150)16450-KPP-T01
23430-KWN-440
- power-full
- Year: 2010
- Color: preta
this is the material ... lol I have also mounted on the pcx malossi variator kit, contrast spring malossi yellow, belt gave up the malossi until see the polini is behaving well..lol
I also have the exhaust in stainless steel with the original tip .. I intend to change but you can not get everywhere €€€€€€€€€) lol
- s-l500.jpg (20.35 KiB) Viewed 4774 times
- PCX125_GearShaft_Set_P01__98309.1399724785.1280.1280.png (53.19 KiB) Viewed 4774 times
- Inertia_Power_Booster__37550.1398580179.1280.1280.png (252.67 KiB) Viewed 4774 times
- 38772-KWN-000A-YUMINASHI-FUEL-ADJUST-CONTROLLER__45402.1528200440.380.380.png (108.72 KiB) Viewed 4774 times
- 12103-KWN-600XA_Flat_Deck_Light_Bore_Kit_PCX125_V1_p01__98826.1463801745.380.380.png (129.36 KiB) Viewed 4774 times
- power-full
- Year: 2010
- Color: preta
homie wrote:That's great!
this Saturday I'll give you news .. lol
- power-full
- Year: 2010
- Color: preta
See
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Enviado do meu GT-I9060I através do Tapatalk
- power-full
- Year: 2010
- Color: preta
