windshield removal
windshield removal
How difficult is it to replace the OEM windshield on a 2015 PCX-150 with something taller? Currently the wind hits me squarely in the chest. BTW, I'm 5'-10" (178cm) tall.
Jim
'15 Honda PCX 150
Pearl White
Motori Tec Inc. Performance Variator w/ 14g rollers
ContiScoot tires - safety recalled
Avon Viper tires
Jim
'15 Honda PCX 150
Pearl White
Avon Viper tires
Re: windshield removal
Very easy to install
Take a look here - http://www.hondapcx.org/viewtopic.php?f=3&t=7278
Lots of posts about which is the best windshield for your height
- Year: 26 adv 160
Two screws, a few 10mm bolts, 10 min swap.....
I have a 2013 model, which is a little different, but I have changed out windshields many times. There is much to it. First I removed the trim that covers up the 4 bolts that hold the windshield on. The trim is held on by two screws and some clips. After that, it is easy...just remove the bolts. That's it. Put it back together in reverse order.
So, just find the windshield you want, and then just go for it.
- pendulum
Something that stumped me for a bit was how to remove that front trim piece without breaking it.
After you remove those two screws you want to slide the trim piece down. Do not pry it upward or outward.
After you do it the first time, it's a 10 minute job. And I'm sure more than a handful of us switch screens for seasons too. ;-)
Good luck!
Good luck!
2015 PCX 150
Dr Pulley 13g
Yoshi SS exh
Dr Pulley 13g
Yoshi SS exh
