Lucky you.Mister Paul wrote:Another poster on here will go on about the rear caliper dragging, but mine was ok.
I was not alone, there have been a few others with this problem and there have been discs and pads replaced under warranty.
Pump recalls... there was the initial one then there was a second one to replace the replacement.
There was also the brake coupling connector recall.
This isn't me moaning, these are verifiable facts.
Another fact is that most owners have no problems and that later ones are tickety-boo and may not need new fuel pumps, brake switches, water-pump seals, or clutch bearings.
If you get a good one and treat it right the Forza 300 is a pretty decent little scooter and despite the problems I experienced I would definitely consider buying another as a winter runabout.
