What is this?
Smaug
Year: 2013 PCX150
Re: What is this?
Post by Smaug »
The big shame is the hole drilled in the body plastic, which may defeat the weather resistance of the bike. Make sure you get that properly plugged up. Honda didn't intend for rain water to be dripping in there.
-Jeremy
Re: What is this?
Just to let you know, that gas cap panel takes a whole 2 minutes to remove. I have replaced several and take mine off almost every time I take my bike apart because that is where my wires run for just about every front auxiliary light I have added, plus I once had an accessory outlet there...well to the left of there on that panel... and the panel is cheap to purchase online.
TheMaverick
Re: What is this?
Post by TheMaverick »
brrit wrote:Ok... Mystery solved.
I had the service tech take a look around the wiring. It led to a wiring harness (relay) that appears to have managed some type of light bar. Go figure.
Damn. Was hoping it was to set the turbo boost!
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Re: What is this?
Post by alx123 »
I'm too late. I was gonna say that's the time travel button. Push when you hit 70mph and boom...
Show us the strobes...
TheMaverick
Re: What is this?
homie wrote:
WhiteNoise wrote:homie has a question :D ...what's yer yella bike in the background?
Mines going sublime green these days no longer yellow, white or black emblem WN... I just can't decide :D
How about something that's more distant from factory colours?
brrit
Year: 2013 & 2016
Color: Red & Grey
Re: What is this?
Post by brrit »
Mel -
You don't happen to have a link to where I could that part, do you?
Re: What is this?
We are talking PCX, aren't we??
Partzilla.com, Bikebandit.com
Look for OEM parts.
http://www.partzilla.com/parts/search/H ... parts.html
Look at item #1
The gas cover is easy to transfer off of the old assembly. You will need to transfer your clips as well, but this is not a hard piece to swap out. Get some plastic auto trim removal tools from some place like Harbor Freight for present and future use.
https://www.harborfreight.com/catalogse ... =Auto+Trim
Re: What is this?
As far as the 2016 PCX is concerned, I don't know if the 2015 model has the same part but here is the page for the 2015 model.
2016 part at bikebandit.com
http://www.bikebandit.com/oem-parts/201 ... #sch939855
Re: What is this?
Mel pre LED PCX body works are quite a bit different than everything 2015 and later. You know this, actually none of the body plastics are interchangeable at all.
Brrit you won't pull a 2018 PCX console panel off in minutes as Mel can on a 2103. It's just not the same bike or the same assembly. If I were you I would wait until you do your valve clearance check which will get you within striking distance of getting the console out and in the mean time I have a perfectly acceptable cosmetic fix for that... ask me how.
Maveric, how in the heck did you do that 8)
TheMaverick
Re: What is this?
homie wrote: Maveric, how in the heck did you do that 8)
It's easy - just open in Photoshop - convert to LAB mode - invert both A and B channels - apply a layer mask - then reveal just the portion we want using a selection.
Re: What is this?
It's going to start a riot over at the Buell forum. They've been waiting to see the new color so I think I will bomb them with that instead :lol: Thanks!
TheMaverick
Re: What is this?
Pleasure is all mine - just let me know if you need any Photoshopping :)
Re: What is this?
Well that Sucks! They took one of the simplest parts to remove from the pcx and turned it into another impossible to remove plastic pig piece!
Re: What is this?
Mel46 wrote:Well that Sucks! They took one of the simplest parts to remove from the pcx and turned it into another impossible to remove plastic pig piece!
:lol: thus we toil some more. Anyhow here is my fix for the members cosmetic issue until routine maintenance has him in there anyway. Like the second seat latch mod you can wait it out and do it when you're under the skins another day.
brrit your LED PCX is riddled with these trim clips where as your pre-15 models have none so you are not familiar or you would have thought this one out yourself. Drill the hole the proper size and pop one in for now... done!
Re: What is this?
Its actually an activation box for a continuum transfunctioner...
Re: What is this?
Or...instead of using a trim clip that homie mentioned above,
You can use a plastic hole plug sold at any hardware store. They come in different sizes and a few colors. I've used them for all kinds of applications. Remove your "what's this" item from the scoot's tunnel area then ride it down to Ace hardware or another nearby. Once there you can size up a plastic plug and be done. Before applying it you can choose to dab the plug in a bit of silicone before seating it.
Plug Examples:
http://www.widgetco.com/hole-plugs?gcli ... gK2EPD_BwE
dgnyberg
Re: What is this?
Post by dgnyberg »
All this talk about "what is this. . ." now I have a project to do.
Time to build a mini flux capacitor and mount it to the fuel door!!
Some strip LEDs, a controller and some inventive building and we'll see what happens!!
_____________________
Dave
KG5VOO
default
Year: 2018
Re: What is this?
Post by default »
Ive seen that switch before. Heres a link to the one I know of. http://stores.advmonster.com/rotary-led ... am-bypass/ (love their lights BTW)
default
Year: 2018
Re: What is this?
Post by default »
dgnyberg wrote:All this talk about "what is this. . ." now I have a project to do.
http://www.thinkgeek.com/product/itti/? ... JwQAvD_BwE
http://www.thinkgeek.com/product/1dbd/
brrit
Year: 2013 & 2016
Color: Red & Grey
Re: What is this?
Post by brrit »
Good stuff, folks. Thanks for all the input on the knob.
Probably going to try and remove it and cover the holes. I figure a tank bag would cover the holes anyway, right?
