Best way to lift a Froza 300 to change rear shocks
Southbed
Color: Red Forza
Post by Southbed »
Does anybody know the best way lift and stabilize the Forza 300 to change rear shock?
The best way to enjoy the day is to be in the wind, If you are riding your not spending money on your ride.
davenowherejones
Color: Silver
Re: Best way to lift a Froza 300 to change rear shocks
Post by davenowherejones »
I would hang it from my ceiling in my shed or use a bike lift. You could also change one shock at a time maybe using the centre stand. A piece of 2x4 jammed in the right place could also be used.
Southbed
Color: Red Forza
Post by Southbed »
Excellent thank you.
SteveP
Color: red
Post by SteveP »
Put it up on center stand and do one side at a time. No 2x4 or other lever needed...virtually no spring load to overcome when Forza on center stand as shock is pretty much fully extended.
SteveP wrote:Put it up on center stand and do one side at a time. No 2x4 or other lever needed...virtually no spring load to overcome when Forza on center stand as shock is pretty much fully extended.
X2
Southbed
Color: Red Forza
Post by Southbed »
Thank you for all of the help.
Southbed wrote:Thank you for all of the help.
De nada amigo.
MBMyer
Post by MBMyer »
X2
x3
This is exactly the procedure I used.
6 other previous bikes
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
So - what shocks are you going with, and where are you getting them from?
Southbed
Color: Red Forza
Post by Southbed »
YSS Shocks Model TC 302-400T
EPM Performance Imports, Inc.
HYPERPRO,GAZI USA, RUN-N-LITES, YSS USA,
77 Pension Road., Suite 17
Manalapan, NJ 07726
732-786-9777
Klaus Huenecke (sales@yssusa.com)
Talked to Klaus, He is presetting the shocks to my weight with gear
Before they ship. So I will have little if any adjustments.
Hope this helps.
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
Couldn't ask for more! Thanks, Southbed.
CamboForza
Post by CamboForza »
I am going to adjust the settings on mine and as you all know the exhaust gets in the way at the back for the spanner to get in there.
If I put it on the center stand and unbolt that shock at the bottom so I can pull it back to adjust the setting, do I need and type of Threadlocker to bolt it back up?
Also, does anyone know offhand what size spanner/wrench I need for the bolt on the shock?
Cheers.
I am looking at the YSS TC-302-400T but I don't want to spend the money yet and https://bikerzbits.com/honda-forza-nss- ... orber.html are charging a lot more on the .com than the .co.th part of their site not including shipping once you do currency conversion.
Honda Forza 300
YSS Front and Rear Upgrade
19 Gram Sliders
Year: 26 adv 160
I would be using red loctite #271.....perm lock
CamboForza
Jge64 wrote:I would be using red loctite #271.....perm lock
Cheers, I'll make sure I pick some up.
Hang on the product specs say...
Loctite Threadlocker Red 271 is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
I want to be able to undo it one day...lol.
Honda Forza 300
19 Gram Sliders
Southbed
Color: Red Forza
Post by Southbed »
I would use the loctite Blue for the bolts on your shocks. I have great success with the blue and use it for all of the fasteners.
Do not use the torque specs. in the manual, they are set for steel and most after market shocks are aluminum. so no more the 4-7 inch lbs.
with the loctite just a little past tight let it set you should have no issues.
Enjoy the ride.
CamboForza
Funny, I went through the tool pouch and found that I have the Honda Factory shock adjuster kit included.
I'm going to try the softest setting to see if that makes it a bit more compliant. I am only 76Kg.
I'm not ready to go and buy new shocks this month or next.
Honda Forza 300
19 Gram Sliders
SteveP
Color: red
Post by SteveP »
Southbed wrote:YSS Shocks Model TC 302-400T
Manalapan, NJ 07726
732-786-9777
Hope this helps.
I see this is from last year. How did the new shocks perform? Is the ride better?
davenowherejones
Color: Silver
I am 90 kg and I have my rear shocks on full soft.
I jam a big screwdriver in the shock spring and gently pry upward to turn the adjuster by hand.
I like it better on full soft, full hard was harsh.
