the best variator/exhaust/drive belt to use for pcx 125
				mikeyboy90
- Color: silver
I ordered a j.costa variator/exhaust set to then to be told that it's only for 2012 pcx 125. which combination of variator/exhaust/drive belt would be best for my pcx 125 2011. any help would be great.
						Re: the best variator/exhaust/drive belt to use for pcx 125
Use them. Should be ok. Not too much differences between those 2 models
I have 2013 model 150s and have NCY variators on them that are advertisedetermined for the 2011 pcx 125. It fits and performs as expected, so I wouldn't worry about whether it is advertised for a 2011 or not.
				mikeyboy90
- Color: silver
seller refused to sell me j.costa set because j.costa have said it's not compatible with my 2011. I'm looking at buying malossi multivar 2000 variator, malossi Kevlar drive belt and c.j beets exhaust (made in japan) just thought I'd see if anyone has used any other parts and know that they work well on 2011.
				u33db
There have been comments about the Malossi belt being poor quality/wearing/snapping.
Their multivar will be good though.
You might want to think about getting their clutch springs too.
Malossi 10.5g rollers
Malossi yellow clutch springs
HJC wind screen
HJC wind screen
				mikeyboy90
- Color: silver
any recommended sports exhaust? I've already brought and installed belt and variator. I'll keep belt I took out just incase it does snap to quickly.
						- pcx888
- Color: pearl white
Which variator and did you end up getting.mikeyboy90 wrote:any recommended sports exhaust? I've already brought and installed belt and variator. I'll keep belt I took out just incase it does snap to quickly.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Knowing where you are located will give us a better idea as to what after-market parts you can get. Please put your location in your profile.
