so is this the sound of a bad bearing
Re: so is this the sound of a bad bearing
Don't buy this until a whisper'er approves but L o_O K what I found and there are several sellers. As soon as we get the go ahead i'm ordering one for quality comparison.
US seller
http://www.ebay.com/itm/CLUTCH-ASSEMBLY ... 9~&vxp=mtr
http://www.ebay.com/itm/GY6-Scooter-Clu ... 2006004764
http://www.ebay.com/itm/Chinese-Clutch- ... W5&vxp=mtr
Alibally
Post by Alibally »
homie wrote:I wonder if you can get the entire clutch pulley assembly. shoes, faces, spring, bearings all of it assembled. That would be a snap to install and what, cost a whole 50 bucks?
Not in the UK it doesn't.
£118 when I checked when mine was noisy.
Rip off UK Honda prices.
Have you tried ebay?
Alibally
Post by Alibally »
I didn't but got one off Webike. Even with the import charges it was cheaper.
That was a while ago though I'm not sure how much they are now.
eggman
Post by eggman »
can some1 post link to the clutch sprin compressor tool? i search and cqr tools only show up
eggman
Post by eggman »
ps do i need a cluth holder tool if i use a impact wrench
eggman wrote:ps do i need a cluth holder tool if i use a impact wrench
Not necessarily the one called for in the SM and shown in this Amazon link but you do need to minimize the impact with something. The jerking can damage gears in the final drive.
DO NOT USE the impact wrench to reassemble anything (use a torque wrench only please)
Large oil filter tools work fine to hold the otter bell on the clutch assembly if you have one.
https://www.amazon.com/Filter-Strap-Wre ... +tool+belt
For the variator assembly you can use something like this or make your own
http://www.ebay.com/itm/Motor-Variator- ... 9k&vxp=mtr
eggman
Post by eggman »
cool illl use torque wrench for reassembly
eggman
Post by eggman »
ps still need a link please for the tool to compress the spring so ican take of the 39mm nut
Many things can do the job, look around the shop. Never had any use for this weird pair of vise grips until owning a PCX. Drilled out the tips and placed a couple steel pins.... works great!
Don't know about the spring compressor tool, seen people using all kinds of stuff other than the proper tool on youtube.
eggman
Post by eggman »
so far thats were im not sure to do i prefre to have the proper tool to compress spting
chicaboo
Post by chicaboo »
Real men use their feet as spring compressors.
eggman wrote:so far thats were im not sure to do i prefre to have the proper tool to compress spting
See if you can find it, I might like one too if you can find a US vendor. Not going to Thailand for one until I have to.
SM nomenclature ----> CLUTCH SPRING COMPRESSOR
Honda Part# 07LME-GZ40201
OR
07960-KM1000B (USA Only)
eggman
Post by eggman »
id hate to take her in i just had alll this done like 4000 miles ago so sad. ps how do i get the grease in the bearring while bearing is in middle of pulley
eggman wrote:id hate to take her in i just had alll this done like 4000 miles ago so sad. ps how do i get the grease in the bearring while bearing is in middle of pulley
7 grams total... knead it into the needle bearings and the other bearing first, then push the rest of the grease into the center of the two bearings. Don't let grease get away form you on anything the belt rides or anything in the vario where the rollers are. Behind the CVT cover is not a place to smear around grease and oil or you will sit and spin. Wipe any excess off the spline's as you carefully reassemble. The nuts are torqued back with a light coat of motor oil (wet torque) procedure to the specified foot pounds.
I going to order one of those clutch packs WHOLE from the US seller and take it apart for a quality check. I'm too curious because that's the way to deal with this issue if its the same part.
eggman
Post by eggman »
ty for all the help every1
You will do this work eggman? or imagining yourself doing it. I'm imagining myself doing it, wish there was something wrong with mine.
eggman
Post by eggman »
homie wrote:You will do this work eggman? or imagining yourself doing it. I'm imagining myself doing it, wish there was something wrong with mine.
im wanting to do it but im not sure i can
:lol: :lol: :lol:
eggman
Post by eggman »
i may still try it i hate to have others fix my stuff
