How-To: Make "Backup" Seat Release (Auxiliary Seat Latch Release)
Decided I'm not going to be the guy who can't get the seat open without a key. Unfortunately you need to have a reason to remove the tail section to do the Mod
Re: Seat release back up ... Auxiliary Seat Latch Release
That sofa in the garage lends me to think that the Mrs must insist that you sleep on the sofa often.
- PCX150Rider
Absolutely brilliant!
First time I adjust the valves I'm going to add that mod to the list.
It's worth shortening the loop on your beaded chain from your window shade right
she will never notice, and if she does I have a couch in the garage.
homie wrote:...... she will never notice, and if she does I have a couch in the garage.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Fabulous, Homie. I would have said brilliant, but PCX150 beat me to it.
I may never lock my key under the seat but surely the battery will fail someday? How do we get to the battery which is under the seat if there is no power to operate the latch? Help me out with that... Honda
You using up your old stock?
Overstocked, but commonly found about the verseyou you wrote:You using up your old stock?
- unnamed (1).jpg (108.45 KiB) Viewed 67916 times
- unnamed.jpg (63.17 KiB) Viewed 67916 times
- PCX150Rider
A couple of ideas slogged their way through my brain (somehow). One is that I have an old "new" brake cable from a bicycle I never used and may try to see if I can re-purpose that . . . although I may have a better chance of winning the lottery.
The other idea is that I may take a sturdy straw, modified section of a ball point pen, or short metal tube to run the ball chain/cable/line through to reduce the risk of sawing action through the Gorilla Tape. I would apply the tape around the tube to secure it to the frame. In essence it would sort of act like a "hawsepipe" for an anchor chain. May have to flair the ends into a bell shape. . .like the bell on a trumpet. . .to reduce the risk of a snag. . .or maybe it won't be an issue. . .especially if I'm able to re-purpose the bike cable. If I use a ball chain then will add a handle. Something like this.
http://www.homedepot.com/p/Westinghouse ... /204832065
Just grabbing at straws . . . no pun intended.
Yep much room for improvement but there won't be any wear as you will not pull it until you need to, the electric actuator from the console is not affected in any way. I can send you the two foot section of plastic beaded chain in an envelope, just PM your address no problem. Fair warning... the tail section of a 15/16/17 PCX is a tricky extraction, you will need the SM for sure.
homie, homie, homie!! I "knew" you'd be up to this! "Sure as I'm Sitting Here!"
FAB-Bu-Los-So!! Where's a Clapping emoticon (smiley) when you need one? Da-ham sir! Hands facing hands and me hat be tipping
I thought about solving this (future) problem, probably at the same time you did. Yeah, you knew that moment, it came quickly. I felt it too.
So I'd lay on my back picturing it's travel path. Then the damn ibuprophen kicked in. I fell off to sleep at the seat latch.
Bet the hardest part of this "it should be Honda Bin Pull" mod is getting the plastics off intact. You're a pro at that, you've gained mucho experience popping the holds that bind them, and without a break.
That alone is worth applauding.
PCX'er's need this genius seat latch opener. You must name this. Example: "homie's seat release."
We shall then call it, as you do. With respect
WN is calling. Sayin'... get with This!
P.S. I see lotsa room in that there garage. You're lucky I don't live around the corner, cuzz holy smoker's I'd be rollin' over jist abt now!
Yes'sum, I gots a s _ _ _load of metal beading. (Think fan pulls ya tooler's)
Yes, good mod.
Thanks WN, for search purposes best not change the header. Sticky post would be cool
If people think about it in time to take advantage of the issue when tail section is off that would be a no brainer. Tail section is removed for valve clearance check, rear shock replacement but not during the 5k inspection unless you choose to look at the fuel line... I did not.
- PCX150Rider
Thanks for offering to send over some beaded chain. I'm good to go right now. My Dad was an engineer who was always futzing with stuff around the house and I've got more tidbits of this and that and that and this than I know what to do with. I grabbed this handful of stuff without evening digging. . ..Yep much room for improvement but there won't be any wear as you will not pull it until you need to, the electric actuator from the console is not affected in any way. I can send you the two foot section of plastic beaded chain in an envelope, just PM your address no problem. Fair warning... the tail section of a 15/16/17 PCX is a tricky extraction, you will need the SM for sure.
But when I get my PCX in a week or so I'll have a much better idea what kind of challenge I'm in for.
Shiver me timbers about removing the plastics without a crack or overlooking a geezzzussss clip somewhere. The SM has been paid for already and ordered. It will either be delivered with the scoot or I'll get it the day I go back to sign for the registration plate. Which reminds me I've got to get a set of those body panel removal tools and order the new electric impact driver/wrench. I've got time though.
I'm planning on using my IPad to watch the step by step instructions in your videos when I do the scheduled maintenance.
No worries, Not changing this threads title homie. No need to. It stays.
As far as a sticky? maddiedog is in control of that. I'll run it by the mods 1st and see what happen's from there.
Errr, what? I didn't learn this word in Murica school back in 82.PCX150Rider wrote:"hawsepipe"
How do you even say it??? Horse pipe, House pipe, Whore's pipe?
- PCX150Rider
Homie - So here are some materials I already had on-hand that I think will work to create a similar emergency seat latch release. Actually I think that's what you should call the invention. . . "Emergency Seat Latch Release".
Notice the tubing. . .I think I've got more buried somewhere but may use these two pieces strategically in the places it seems the connection meets the most resistance on the frame. The G-Tape should do nicely to secure it in place.
It doesn't appear from the video that it takes much effort to activate the seat latch release mechanism. It's a bit difficult to see the attachment method you used on the latch lever itself but it appears that there must be some kind of slot that the ball fits into?
I'm not sure what the distance is from the latch to the access area under the side panel (you mentioned a 2 ft. length of ball chain to cut from?) but I think what's shown in my pic here would be adequate. I may be able to use the lamp cord only. . .or the line included for the Traverse Cord Kit in the other post. It's the attachment method on the latch assembly itself that I'm not certain of. Any way you can describe it? I've got crimp connectors and other assorted stuff to Rube Goldberg or MacGuyver the thing.
- PCX150Rider
The way I've heard it said sounds like hawwwzzzzpipe. But now that you mention it. . .it could be some nice lady's prize possession to enjoy some cherry blend.Errr, what? I didn't learn this word in Murica school back in 82.![]()
Let's hear what the experts have to say shall we? https://www.youtube.com/watch?v=WMTuFcZAvIM
It's all about how one pronounces the "e".
Oh no, Mexican robots trying to teach me how to pronounce vague American words.PCX150Rider wrote:Let's hear what the experts have to say shall we? https://www.youtube.com/watch?v=WMTuFcZAvIM
I'm still torn between "Horse pipe" and "Whore's pipe". And what do either of them need with a pipe anyway?
